Wiring diamgram (s), Tach, combo gauge |
partwerks |
Jul 13 2016, 07:38 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
76-914 |
Jul 13 2016, 07:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did you check Jeff B's website?
partwerks |
Jul 13 2016, 07:50 PM
Mike Bellis |
Jul 13 2016, 10:15 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Did you check Jeff B's website? Don't know about it. Do you have the link handy? Jeff has a great site. save this link... http://bowlsby.net/914/Classic/ |
Mark Henry |
Jul 14 2016, 05:45 AM
Likely you already know this but that is 911 stuff, are you trying to figure out wiring for a /6 conversion?
914Sixer |
Jul 14 2016, 06:04 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Combo gauge requires wire run from console harness plug to dash board. You will need two jumpers for the red wire for 12v and a brown jumper for ground. Electric speedometer requires a bunch of stuff.
partwerks |
Jul 14 2016, 10:19 PM
Trying to help with some of the leg work for the mechanic, and the LS3 conversion. Everything takes time.
timothy_nd28 |
Jul 14 2016, 11:11 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Tach is wired correctly in the top picture. The mechanic will need to intercept the black wire with purple stripe (wire on the middle terminal) back at the relay board and reroute that wire to your LS3 ECM's tach output pin. The ECM should have 3 connectors that are colored, one of the connectors will have the pin that you are seeking.
Also, Some LS ECM's will have such a weak weak signal, he may need to install a pull up resistor to make the tach work. The combo gauge is pretty straight forward, seems that this mechanic is more mechanical and less electrical. Retrofitting a LS into a 914 is serious business and will take some knowledge and thinking outside the box. I would hate to see your converted car have some electrical fire because this mechanic is not up to snuff with wiring. Not to be taken the wrong way, just my .02 cents |
Lo-Fi Version | Time is now: 8th June 2024 - 09:43 AM |
