vacuum advance/retard, rebuild? |
hndyhrr |
Aug 3 2016, 04:26 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Vacuum advance/retard can(for lack of better description) on my car which is a 70,1.7 with FI needs help, the retard side does not work. Can this be rebuilt? Do I have to replace it and if so do i need to find one compatible with the dizzy?
While I am asking questions had Petronix ignition installed would it be better to put in petronix coil? Thanks |
Mblizzard |
Aug 3 2016, 05:55 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
OK to be clear 1.7 is not my strongest knowledge area. I think the 1.7 only has an advance canister. The retard function is not really necessary except for meeting emission requirements. I am not sure they make the replacement cans anymore.
porschetub |
Aug 3 2016, 07:57 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As mentioned the retard isn't required unless you have EPA smog testing,as long as your advance side is working you are fine.
ALWAYS match the right coil with Pertronix,the early ones will run with a Bosch blue coil or the one supplied by them,the Ignitor 2 has a lower resistance coil required and from memory can't be used with sold core wires to counter RF inteferance. Buy The Ignitor 2 system and matching coil and do a full ignition service including nice leads like Clewitt Engineering or Magnacore as some have mentioned but I haven't used them. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:20 PM |
