which octane? |
which octane? |
Gearren |
Apr 13 2005, 06:41 PM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
I have a 73 2.0 with webbers, and I have been using the middle grade gas, but does it make a difference which grade i use with the rising gas prices?
SirAndy |
Apr 13 2005, 06:43 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
stock internals? if so, you should be able to get away with low grade fuel. just try a tank and see if you get engine *knock* ... if not, you're fine ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
jr91472 |
Apr 13 2005, 07:17 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I get bad run on with the mid grade stuff. Have to go premuim$$$$$$
ArtechnikA |
Apr 13 2005, 07:20 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
check your timing, and your spark plug heat range. dribbly injectors won't help. and maybe find a better class of gas station ? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
p914 |
Apr 13 2005, 08:07 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
Run premium. your plugs won't get burned up, your engine will run smoother and the milage will be better in the long run.
SirAndy |
Apr 13 2005, 08:12 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) a stock 1.8L should not need premium ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Aaron Cox |
Apr 13 2005, 08:18 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
yup... too much advance and you will detonate (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
kermit |
Apr 14 2005, 12:46 AM
Member Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 |
lowest octane possible, without knocking!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Always!!!!!!!!!!!!!!!!!!!!!!
just don't ask about whats the best motor oil to use or the pros and cons of steel braided brake lines - PLEASE! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:33 AM |
