> Stumped, Low Compression
AKJammer
post Sep 7 2016, 09:04 PM
Engine: 1.8 1974.
I tore down the engine to replace Dead gaskets and seals.
Purchased new jugs and pistons reassembled the engine. Fired it up and have 90 lbs of compression on 3-4 125 on 1-2.
Completed a leak down test and all is good as it is holding what compression there is...
Tore the engine down again and measured the cc of the heads and they are all the same. Part number 021.101.371S on both heads.
Measured the deck height of the pistons at TDC and they are all the same....
Head gasket shims are all the same.
What am I missing???
Thanks Jammer!
rgalla9146
post Sep 7 2016, 09:14 PM
Fuel injection or carbs ?
If carbs, were the carbs open on both sides ?
AKJammer
post Sep 7 2016, 09:19 PM
QUOTE(rgalla9146 @ Sep 7 2016, 07:14 PM) *
Dual 40's and just rebuilt. They were opening. Thanks
injunmort
post Sep 7 2016, 10:29 PM
ring gap, ring stagger, valve seats, valve clearance, piston to wall clearance, your missing a lot.
AKJammer
post Sep 7 2016, 10:46 PM
QUOTE(injunmort @ Sep 7 2016, 08:29 PM) *
Thanks!
But do Brand new Pistons and cylinders leak? If they were bad would that not show up on the pressure test? Also Would the valve seats held pressure during the pressure test if they were a problem?
Valves adjusted by myself and rechecked by another person, and they were good.
wndsrfr
post Sep 8 2016, 05:27 AM
QUOTE(AKJammer @ Sep 7 2016, 08:46 PM) *
Thanks!
Rings haven't seated.....drive it like you stole it a couple days & check again....
rgalla9146
post Sep 8 2016, 05:42 AM
QUOTE(AKJammer @ Sep 7 2016, 11:19 PM) *
When doing a compression test the carbs must be propped open.
"they were opening" doesn't sound right.
stugray
post Sep 8 2016, 05:49 AM
QUOTE(wndsrfr @ Sep 8 2016, 05:27 AM) *
And the engine is supposed to be warmed up as well.
TheCabinetmaker
post Sep 8 2016, 06:00 AM
I drive my car everyday
Sounds like an aka problem
VaccaRabite
post Sep 8 2016, 07:57 AM
En Garde!
Compression on a fresh top end-er builds as the rings seat.
So assuming you cut your ring gaps correctly... Here is how I was taught to break in a fresh motor.
Warm it up. When at operating temp, on your favorite quiet road, put the car in second gear and STOMP ON IT. All the way up the rev range. Then foot off and let the car engine brake back down (keeping the car in second gear). Do that two more times.
Your rings should now be seated, and compression should be around 140-160 or so.
Zach
injunmort
post Sep 8 2016, 07:58 AM
if it were mine and it is out and apart. i would do a light hone on the cylinders (break the glaze), check my ring gaps again, stagger the gaps at 60 degrees and reassemble the cylinders. on the heads, fill each combustion chamber with lighter fluid with spark plugs in the holes and check for leakage past the seats. the chambers should hold the fluid. if they don't, lap the valves into the seats and try again until it seals. reassemble.
AKJammer
post Sep 8 2016, 12:10 PM
Thanks All! I have some Ideas of what to do now! See if I can get this up and running before snowfall!
BTW what is an AKA problem? if your referring to Knowledge then yes... I am a noob. (IMG:style_emoticons/default/piratenanner.gif)
Root_Werks
post Sep 8 2016, 12:15 PM
Village Idiot
QUOTE(rgalla9146 @ Sep 8 2016, 04:42 AM) *
I agree, it might be why a leakdown will show something like 80/79, but a compression will show 90psig. You need to allow air into the intake system. Prop the throttle to stay open and re-run the test.
AKJammer
post Sep 8 2016, 01:07 PM
QUOTE(Root_Werks @ Sep 8 2016, 10:15 AM) *
Yep will do! But either way the plugs were not firing on 3-4 side unless I had the rpms up. I installed new cap rotor pertonics points coil wire and plugs.....
r_towle
post Sep 8 2016, 07:05 PM
Custom Member
You may want to check to make sure the case is flat where the cylinders set.
Older cases have been known to sink in the middle and that makes sealing the heads nearly impossible
Root_Werks
post Sep 9 2016, 10:18 AM
Village Idiot
Also noting you stated 3-4 "side" doesn't fire until the rpm's are up. Sounds like an idle circuit adjustment/issue/vac leak etc. more than compression.
old dog
post Sep 9 2016, 08:54 PM
Just a thought.... Is the cam timing correct ? Good leakdown, different compression side to side.... Cams not timed properly
Again, just a thought.
rgalla9146
post Sep 10 2016, 04:03 AM
QUOTE(old dog @ Sep 9 2016, 10:54 PM) *
......that would require a Very special cam
- Lo-Fi Version Time is now: 15th March 2026 - 11:42 PM
