Scratched Glass |
Scratched Glass |
cal914 |
Sep 13 2016, 01:09 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I have a few scratches on my door glass,is there any way of getting them out
Thanks Brian |
Mike Bellis |
Sep 13 2016, 06:52 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Yes. Call an expert. If the gouge is not too deep, it can be polished out. Buy the time you buy all the tools and get past the learning curve, you could have hired the expert.
Mikey914 |
Sep 14 2016, 11:06 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have a low RPM kit that's $65, if you wanted to give it a shot you may be able to at least make them much less visible
http://shop.914rubber.com/Scratch-Magic-Pl...m?categoryId=-1 |
rgalla9146 |
Sep 14 2016, 12:49 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
DavidSweden |
Sep 15 2016, 03:49 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have a few scratches on my door glass,is there any way of getting them out Thanks Brian Windshields yes. Side glass not too sure. I've got a kit and I've got a lot of patience. No dice. At least for me. When you way windshield yes is it possible? My windshield looks like its been sand blasted and its not possible to drive when the sun is low. How do I fix it? |
mepstein |
Sep 15 2016, 04:36 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a few scratches on my door glass,is there any way of getting them out Thanks Brian Windshields yes. Side glass not too sure. I've got a kit and I've got a lot of patience. No dice. At least for me. When you way windshield yes is it possible? My windshield looks like its been sand blasted and its not possible to drive when the sun is low. How do I fix it? Replace it. Over time, it does get sand blasted. Especially highway miles behind trucks. |
rgalla9146 |
Sep 15 2016, 05:54 AM
I have a few scratches on my door glass,is there any way of getting them out Thanks Brian Windshields yes. Side glass not too sure. I've got a kit and I've got a lot of patience. No dice. At least for me. When you way windshield yes is it possible? My windshield looks like its been sand blasted and its not possible to drive when the sun is low. How do I fix it? Scratches in a windshield can be removed. Small craters caused by highway sandblasting are different and I'm not too sure it's possible to remove them . They're more like small holes. I'v got a kit that has two grades of rare earth, special polishing "cloth" like material a 4" polishing head and other stuff too. I worked on tinted side glass for hours. 0 results Windshield glass and side glass are different types. |
JawjaPorsche |
Sep 15 2016, 06:40 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I have a few scratches on my door glass,is there any way of getting them out Thanks Brian Windshields yes. Side glass not too sure. I've got a kit and I've got a lot of patience. No dice. At least for me. When you way windshield yes is it possible? My windshield looks like its been sand blasted and its not possible to drive when the sun is low. How do I fix it? Replace it. Over time, it does get sand blasted. Especially highway miles behind trucks. (IMG:style_emoticons/default/agree.gif) Replacement is the only answer. You can not repair sandblasted windshield. I wasted money and time trying. |
whitetwinturbo |
Sep 15 2016, 09:41 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
This will continue to grow as laws keep forcing manufacturers to make glass "softer".
Mikey914 |
Sep 15 2016, 10:23 AM
The windshield is laminated glass 2 thin layers. It is not tempered. The side glass is tempered. And I have used the kit to reduce the scratches on a temped glass railing system. this is the main reason I carry it.
Valy |
Sep 15 2016, 10:35 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
If you have to do it, you can cover the glass with a thin layer of epoxy and then polish it.
It's the same idea as the small damage windshield kit repairs. |
Mikey914 |
Sep 15 2016, 10:50 AM
If you think about it, the process would be very similar to the headlight repair for the newer plastic housings. They add a "protective coating"
http://www.target.com/p/meguiars-headlight...mp;gclsrc=aw.ds Probably not the best option for the windshield, but kind of the idea. |
76-914 |
Sep 15 2016, 05:46 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I polished out a scratch in my canopy once. That small 2" area distorted the view when looking thru it. (IMG:style_emoticons/default/blink.gif)
Mikey914 |
Sep 16 2016, 12:29 AM
For what you can buy one for, it may not be worth the effort.
Cuda911 |
Sep 16 2016, 03:34 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I agree with the "replace it" comments for scratched glass. I did a bunch of internet research on glass scratch removal. I thought there would be lots of people successfully doing this like the plastic headlight restoration. What I found was that for a huge effort, you get crappy results.
Lo-Fi Version | Time is now: 10th June 2024 - 08:01 AM |
