tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
(Also posted on pelican parts)
I have been using modified zenith carbs for my 2.7. A while ago I obtained a set of webers however I just haven't had time to rebuild them til recent. They were pretty dirty however they are cleaned up now. When I was trying to set up the carbs, I found that my accelerator pumps were spraying different amounts. Here are the amounts Cyl 1- 0.9cc Cyl 2-1cc Cyl 3- 0.5cc Cyl 4- 0.9cc Cyl 5- 0.5cc Cyl 6- 0.4cc It is clearly easy to adjust the amount on one bank however I how can I between the different individual cylinders? Also, what is the proper amount they should be spraying? I believe it is 0.5 +/- 0.1cc on zeniths however not sure on webers. |
Lo-Fi Version | Time is now: 13th July 2025 - 08:36 PM |
