What am I looking at here? (Cam question), "Dial-in-Cams" old school parts... |
audio_file |
Sep 24 2016, 04:56 PM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
Trying to figure out the guts of my 2.0 so that I can have my carbs tuned for the engine. How do I identify this, is this the bolt on web cam gear, or is it stock, and is the number on the cam significant?
Thanks Chris (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-13409-1474757784.1.jpg) |
audio_file |
Sep 24 2016, 05:09 PM
On further inspection (cleaning) the outside of the cam end cover says "patented dial in cams"
Mueller |
Sep 24 2016, 05:15 PM
interesting, 0° , and +/- 1° to 2° adjustment.
Cannot tell from the picture which one was picked. (not 0° from that one picture) |
audio_file |
Sep 24 2016, 06:21 PM
Some cool info I've found (vwvortex)
QUOTE There's a paragraph on it in Per Schoroder's book "Volkswagen Sport Tuning for Street and Competition". It's starts as full advance at low RPM and retards at high RPM. There is a bunch of weights and springs that centrifugally retard timing as RPM increases. Techtonics dyno it with about a 2hp gain down low without a loss on the high end. It was quite expensive at around $300.00. Anybody have any more info? Attached image(s) |
porschetub |
Sep 25 2016, 02:19 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bob Walter dial a cam if I remember right,very old school.
veekry9 |
Sep 25 2016, 03:31 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Statically adjustable,manual setting. Back to back dyno and track testing to measure theoretical advantage. https://www.google.ca/search?q=advanced+ret...EhxcvC4mbTYM%3A https://www.google.ca/webhp?sourceid=chrome...%20valve%20lift http://www.badasscars.com/index.cfm/page/p...prod/prd358.htm https://www.google.ca/webhp?sourceid=chrome...le+valve+timing As long as there have been piston engines,there has been variable valve and spark timing. Really,clockwork derived from water wheel grindstones,for a millennium of industrial revolution. (IMG:style_emoticons/default/smile.gif) / |
ChrisFoley |
Sep 25 2016, 12:05 PM
I am Tangerine Racing Group: Members Posts: 7,932 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The Dial-in-cams 914 cam was not automatic.
IIRC, only their belt drive external cam gears had that feature. |
Mark Henry |
Sep 25 2016, 12:40 PM
Advancing the cam will add more low end power, while retarding the cam will add power in the upper rpm range. Each does this at the cost of the other.
Advancing or retarding the cam also shifts the powerband up or down the rpm range. The cam could be any brand with just a Dial-in Cam gear. |
audio_file |
Sep 25 2016, 01:56 PM
The cam could be any brand with just a Dial-in Cam gear. And this is what I hope to figure out, what actual cam this is, can't seem to reference the "76" stamped on it to anything... Thanks for the input on the cam gear everyone! The car put down 118hp with hit set the way you see it, so I don't see any reason to screw with it, just an interesting part I want expecting to find in there! (IMG:style_emoticons/default/WTF.gif) |
Mueller |
Sep 25 2016, 03:18 PM
The cam could be any brand with just a Dial-in Cam gear. And this is what I hope to figure out, what actual cam this is, can't seem to reference the "76" stamped on it to anything... Thanks for the input on the cam gear everyone! The car put down 188hp with hit set the way you see it, so I don't see any reason to screw with it, just an interesting part I want expecting to find in there! (IMG:style_emoticons/default/WTF.gif) A 2.0 with 188hp? Crank or at the wheels? |
audio_file |
Sep 25 2016, 04:09 PM
The cam could be any brand with just a Dial-in Cam gear. And this is what I hope to figure out, what actual cam this is, can't seem to reference the "76" stamped on it to anything... Thanks for the input on the cam gear everyone! The car put down 188hp with hit set the way you see it, so I don't see any reason to screw with it, just an interesting part I want expecting to find in there! (IMG:style_emoticons/default/WTF.gif) A 2.0 with 188hp? Crank or at the wheels? (IMG:style_emoticons/default/biggrin.gif) 188 on my keyboard, haha! Thanks, typo fixed! |
r_towle |
Sep 25 2016, 05:58 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The best way to be sure would be to measure the timing and lift with a degree wheel and dial indicator mounted to measure from the push rod to make the math easier .
Lo-Fi Version | Time is now: 23rd May 2024 - 03:01 PM |
