Clutch Slips on 6 conversion |
Catorse |
Oct 2 2016, 03:16 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
So here's the deal:
- built 2.7 with Webers. All the tricks possible on this motor - rebuilt trans - new flywheel (not resurfaced!) - new 914 clutch - New TOB - new clutch cable Cable is adjusted so that engagement point is as close to the floor as possible. When I go above 4000 RPM, I get some serious clutch slip. So bad I can't really climb higher, although the car has a 7K limit. I'm thinking the stock 914 clutch can't hold it, even though it is a brand new clutch. Any ideas here? I do not believe it is making enough power to overwhelm the stock clutch, unless the stock clutch is super weak. |
Steve |
Oct 2 2016, 03:21 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I ran a 2.7 with webers, headers,etc. and had no problems with the 215mm 2.0 flywheel and 2.0 clutch. Maybe you got some bad parts or got oil on the disk. I put over 100k on that clutch, up and down hills, drag racing other porsches, etc.
Catorse |
Oct 2 2016, 03:26 PM
I ran a 2.7 with webers, headers,etc. and had no problems with the 215mm 2.0 flywheel and 2.0 clutch. Maybe you got some bad parts or got oil on the disk. I put over 100k on that clutch, up and down hills, drag racing other porsches, etc. That's what I needed to hear, Steve. I wonder if there is oil or something on it. I seem to recall a slight fluid spill on the bottom of the bellhousing. Wonder if it slung it all over the place. |
wndsnd |
Oct 2 2016, 03:30 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Or the clutch is fine and you are spinning the wheels! (IMG:style_emoticons/default/smile.gif)
Catorse |
Oct 2 2016, 03:40 PM
Naw, got super stick Nitto Nt01, also new. No way they are spinning.
r_towle |
Oct 2 2016, 04:21 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is the pressure plate new?
Has the flywheel ever been resurfaced? You can get pressure plates with more force if required, racing applications. |
Catorse |
Oct 2 2016, 04:27 PM
Is the pressure plate new? Has the flywheel ever been resurfaced? You can get pressure plates with more force if required, racing applications. Brand new flywheel, brand new pressure plate. I am starting to lean towards the oil on clutch theory. I recall spilling some swepco by the bell housing, not sure how much it takes to contaminate the disc but I am guessing not much. |
rgalla9146 |
Oct 2 2016, 05:33 PM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
"The clutch is adjusted so engagement point is as close to the floor as possible"
Correct clutch adjustment has nothing to do with "from the floor" Free pedal movement from the pedal top stop to resistance is the conventional measure of clutch adjustment. |
Steve |
Oct 2 2016, 05:42 PM
I always did the infamous 1/2" free play, pulling the clutch pedal to you versus where it rests.
I never heard of the push to the floor method. There needs to be around 1/2" free play in the cable. |
r_towle |
Oct 2 2016, 05:48 PM
Could be a bad pressure plate too, unless you poured lots of oil on the dick
db9146 |
Oct 2 2016, 08:02 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Kennedy Engineering has a 228mm set-up that they recommend for a warmed over 2.7 mated to a 901. I just went through this getting ready for my swap this fall.
SirAndy |
Oct 2 2016, 09:13 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Kennedy Engineering has a 228mm set-up that they recommend for a warmed over 2.7 mated to a 901. I just went through this getting ready for my swap this fall. (IMG:style_emoticons/default/agree.gif) Get the Kennedy Stage II and never look back. It'll be perfect for your 2.7L ... (IMG:style_emoticons/default/thumb3d.gif) |
shoguneagle |
Oct 2 2016, 09:16 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I have a Stage 1 228mm clutch plate and pressure plate holding behind a 3.2 conversion. The clutch is doing very well holding all the power to a 901 transmission. Not having any trouble with the clutch whether cable or a recently installed hydraulic one.
I would work from the theory of the clutch and the pressure plate and what is needed to hold your engine's power. |
Catorse |
Oct 2 2016, 09:38 PM
In any case looks like the trans is coming off to have a look inside. Has to be something...this thing makes MAYBE 230hp. I doubt that would totally overwhelm a stock 914 clutch
cali914 |
Oct 2 2016, 09:41 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Catorse |
Oct 2 2016, 10:03 PM
So to all you guys recommending the Kennedy, do you really think I have too much motor for my clutch?
Steve |
Oct 2 2016, 11:34 PM
I didn't need it. My motor was a fresh 911s 2.7 with webers and headers.
I would make sure you have 1/2" free play first before pulling it apart. |
sixnotfour |
Oct 3 2016, 02:24 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
adjust your clutch |
Mark Henry |
Oct 3 2016, 08:42 AM
I know it's not a /6, but my type 4 in a bug is 180hp with 20,000km, I can feel a hair of slip if really honk on it. I also undercut my PP by .010" to give a bit more pressure.
I'd say that 180hp is about the threshold of the 215mm PP. |
bdstone914 |
Oct 3 2016, 09:58 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Lo-Fi Version | Time is now: 1st June 2024 - 10:08 PM |
