Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
I'm about 3 hours into my first powdercoating adventure. Man, this stuff rocks. Again, Ginter is right. If you have a garage, and don't have your own setup - you might want to rethink that.
My setup from Columbia Coating, including about 8 pounds of various metallics/clears was about 200 bucks. Pam picked up some extra natural corks (because she saw it on American Chopper). They seem to work as well as the synthetic/plastic corks for plugging bolt holes. I will post pictures later... gotta get back out and monitor temps. -Rusty (IMG:style_emoticons/default/smoke.gif) |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
I thought you were doing this in a parking lot????????????????????
elmonte |
Member ![]() ![]() Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 ![]() |
What are you using for heat? THE SUN!!
Lawrence |
I removed the entire front suspension, and took it to Pam's garage, where we're doing the powdercoating.
For heat, we're using a 28,000 BTU propane heater. It's not ideal, but it's a solution if you don't have 220 power in your garage. Pictures soon. -Rusty (IMG:style_emoticons/default/smoke.gif) P.S. You joke about the sun, but that's actually been done. Ask Ginter for the details - I don't remember enough of the story to tell it correctly. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Yup. A guy sent me pics of an old Weber BBQ grill with sides he built and painted it all black. Powdered his parts and placed them in the grill in the sun for the afternoon. He said it had been years since he coated them and they were still mint.
elmonte |
What temp do you need to get to and how long do need to
hold it there? |
Gint |
Finer details really depend on the powder used (spec sheet will tell you). But generally speaking 400F +/- for 20 minutes after flow out. Flowout is when the powder liquefies and turns to a glossy finish (that's how you tell it has occurred). Flow out usually takes around 5 minutes, but that is dependent on the size (mass) of the part.
elmonte |
Gint
thanks for the info Rusty- Curious to see your setup. For some reason my wife says NO!!! to any powdercoat in her oven.. THANKS |
mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Please, tell me more (IMG:style_emoticons/default/pray.gif)
I have access to two desicant ovens at work. Nothing like a goverment job after hours (IMG:style_emoticons/default/beer.gif) No wonder a guy about 20 miles away only wants 30 bucks to do a couple of parts. |
Gint |
It's not hard or technically challenging. It can be tedious though. Trying not to knock your part or blow or knock the powder off the part while getting it in the oven, stuff like that. It's almost not worth your labor as compared to having it done professionally. Unless you're really cheap. On the other hand, it's nice to do it yourself. And handy to be able to blast and powder coat anything you want even at a moments notice.
Pull a rusty metal part off the car during routine maintenance? No problem! Bead blast, powder and bake! |
mr914 |
It does help if you have the resources to do it yourself......
Besides, I'd love to know how to do it myself. It's like brewing your own beer, the first few batches are fun, then it turns into a pain in the ass.... (IMG:style_emoticons/default/beer.gif) |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
QUOTE(Gint @ Jun 24 2003, 03:37 PM) It's almost not worth your labor as compared to having it done professionally. Unless you're really cheap. Did someone call my name? (IMG:style_emoticons/default/laugh.gif) Good going, LB. I've thought of trying the gas heater idea also. It would be pretty easy to make a reflective hood to help heat the parts uniformly and not have to rotate them as much. Can anyone report on how well it works on aluminum? |
Mike T |
can't 'member ![]() ![]() Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 ![]() |
To do this in an oven, it needs to be electric? Gas won't work?
Mike (no 220v in garage) T |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
I saw some pics on a site that showed them cureing with a round propane heater on the top of a 20lbs tank. They were using a piece of plywood as a reflector. Think I bookmarked it, but I'm at work now. Will look tomorrow.
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
QUOTE Mike (no 220v in garage) T Heh.... We have 220V everywhere and I have even 360V in garage, but I dont know where I could buy the powder (IMG:style_emoticons/default/confused24.gif) Different continentals, different problems.... |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Plywood as a reflector for a propane heater? Sounds a little iffy to me.
Mike |
Lawrence |
My source for powdercoating is:
Columbia Coatings Their website needs some professional help, but the product is good. If you check the Online Store for the Chicago Electric powder kit, it's the best deal. $135.00. It comes with powder, PC masking tape (the good green stuff), plugs of various sizes and hooks. Attached image(s) ![]() |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,633 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I wonder if a gas grille could be used? You could potentially put some sheet metal, slab of slate/rock/brick or whatever over the grille area to even out the heat. Or just get it super hot and then turn off the burners. My grille has ceramic tiles that absorb and radiate quite a bit of heat after the flame is off.
Lawrence |
A gas grille would be good, if you could find an old one.
The key is keeping a steady temp. I'm checking that thermometer every 2-3 minutes (Walmart, about 2 bucks.) Sorry no pics yet. I forgot my camera-to-computer cable. Plywood as a heat reflector sounds like a recipie for fire. I'm using heavy grade sheet steel. |
Jeff Bonanno |
il dottore ![]() ![]() Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 ![]() |
Rusty,
wha's the electro-gizmo thingy for in that setup? what is the procedure (readers' digest style)? jbb (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 04:08 AM |
