914-6 Oil Filler Cap, Can it be plated? |
gcrotvik |
Nov 26 2016, 01:04 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I have an OE oil filler cap that needs to be replated. Are there replacement seals? I believe it's cork.
Thanks, Greg |
jmill |
Nov 26 2016, 05:05 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
You can buy sheet cork and just cut a new one yourself. Back in the day I used to make gaskets all the time. Napa or others should have the material.
mharmon |
Nov 26 2016, 05:54 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
Yep - I've plated a couple of these.
there are rubber seals that will work in place of the cork if you don't want to use the cork |
bdstone914 |
Nov 26 2016, 06:34 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have an OE oil filler cap that needs to be replated. Are there replacement seals? I believe it's cork. Thanks, Greg In stock at Pelican for $2.90. http://www.pelicanparts.com/cgi-bin/ksearc...ion=90120127200 |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:38 AM |
