Oil Pressure Sender, Leaking sender unit |
ricardo |
Dec 2 2016, 08:54 AM
Newbie Group: Members Posts: 47 Joined: 9-November 16 From: Lakeview, NY Member No.: 20,572 Region Association: North East States |
I am having trouble starting my '74 1.8. It turns over an tries to start but it just won't catch. My oil sender is leaking from the top of the unit, not around the threads.
My question is, would a bad sender unit prevent the engine from starting? |
jcd914 |
Dec 2 2016, 10:04 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
On a stock 914, no.
Oil Pressure switch is not tied into any of the fuel or ignition systems. Check the basics first, fuel, spark, compression. Then read up on FI diagnosis, L-Jet on 1.8. L-jet is very susceptible to vacuum leaks and blow air flow meters from back fires. Jim |
IronHillRestorations |
Dec 2 2016, 10:35 AM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If it's a stock oil pressure sender (it's really a pressure switch) I've got some. If you have an oil pressure gauge then you need to be sure to get the same sending unit. Oil leaks on the top of the engine can cause a build up of crud that can give you cooling problems.
As Jim said, the oil pressure switch has nothing to do with your starting problem. You need to go down the standard "non start" list until you find the trouble. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:23 AM |
