Fuel Pump Question, Getting It Ready To Run Again |
74914LE |
Apr 27 2005, 10:30 AM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
I am working on getting a FI Fuel Injection System working again after being off
of the car for many years. The PO said that everything worked when the system was pulled from the engine and put in a box in favor of carbs. Question is, what are the tried and true methods for making sure that the fuel pump has the best chance to start up again? It has been sitting up for 10+ years. Any suggestions? Thanks, 74914LE |
SLITS |
Apr 27 2005, 10:33 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Don't run it dry!
Put some fuel in the tank...disconnect the pressure hose and place into a container. Wire the pump directly to the battery for the test. If it runs and pumps...hook the lines back up. Pressurize the system by connecting to the battery again and see if you have any leaks. rock & roll if it doesn't. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:24 AM |
