Steering wheel hub adapter (re-titled), some help before I dive in |
cooper951 |
Mar 19 2017, 10:02 AM
Member Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
I purchased an aftermarket steering wheel which comes with a hub adapter. Does the adapter simply attach to what's there after I remove the wheel? There are three screws on the bottom of the adapter that are partially seated. Instructions that came with the wheel are minimal. Anybody know what those screws are for? Does the hub adapter just slide on the grooves of the steering column? TIA
Mike Bellis |
Mar 19 2017, 11:16 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
3 screws on the bottom are for the horn ring. Remove this ring from your original steering wheel.
Lo-Fi Version | Time is now: 12th June 2024 - 02:53 AM |
