fuel tank filter/sock,install Question |
flmont |
Apr 11 2017, 06:52 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I got a new fuel tank filter/screen from Tangerine Racing,..and they also sent along a washer,..and Iam guessing that it is for the fuel line nut on the bottom of the tank,?? (IMG:style_emoticons/default/confused24.gif) Thanks Frank
cwpeden |
Apr 11 2017, 07:12 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
The sock has one built-in. Its probably for the return line, is it fibre or metal?
flmont |
Apr 11 2017, 07:36 PM
metal,..thats what Iam guessing, Its for the fuel line nut on the tank,.No other place that needs a washer... Thanks FM
cwpeden |
Apr 11 2017, 07:45 PM
metal,..thats what Iam guessing, Its for the fuel line nut on the tank,.No other place that needs a washer... Thanks FM http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf I'm mistaken Got to Main Group 2: The first image will show what goes on the bottom of your tank. But I thought the washer was fibre. Call the supplier, I'm sure they can explain if its an update or otherwise. |
flmont |
Apr 11 2017, 10:00 PM
Hey cwpeden,..Thanks for the parts info,..Helps a great deal,...Frank
Lo-Fi Version | Time is now: 9th June 2024 - 10:10 PM |
