Seat Belt Warning Lamp Lens, Whatbis the easiest way to get it off? |
914_teener |
May 14 2017, 01:31 PM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
This bulb has burnt out I I suspect it is causing problems with the flasher relay.
Looks like a beoch to get off. Anyone with experience apreciated. |
914_teener |
May 14 2017, 01:32 PM
iankarr |
May 14 2017, 01:38 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The lens is held in by 4 small plastic tabs about 1/8 from the corners. If you take a jewelers screwdriver and gently pry the top of just the red part, it should pop out.
914_teener |
May 14 2017, 01:43 PM
Oh....great. Thanks that is helpful...didn.t know there are tabs as I was pushing on it seemed like something wanted to break.
ConeDodger |
May 14 2017, 01:47 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Fingernails work too...
iankarr |
May 14 2017, 03:14 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 03:51 PM |
