Great! now whats wrong?, Crane Ignition |
72914S |
May 11 2005, 08:19 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Car was running great until I decided to install the crane 700. Details are; 2.0 w/ 96mm flat tops,mild cam,H D springs,stock F.I.,MSD 6A. It was running quite good w/ points,small stumble at 5600 rpm`s. Now at lower rpm`s it really sputters but at 2800 it really kicks in but still sputters at about 5600 unless I ease into it; right up to 6000 (may put in the 7000 chip) I`m wondering about (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) that spider web of hoses.I did double check the timing(stock setting) any ideas?
xsboost90 |
May 11 2005, 08:36 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
is your advance still working right since youve installed the unit?
nebreitling |
May 11 2005, 08:55 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
not a whole lot of info to go on there.... swap back in the points and see if the problems go way... if installed correctly, however, it's hard to imagine the xr700 doing anything like that, so i think your problem is elsewhere.
start w/ ignition.... move to fuel..... classic troubleshooting... |
72914S |
May 12 2005, 01:22 PM
It was a broken wire at the head temp switch. It`s running better than ever now . Going to look for some curves now , see ya. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 02:22 PM |
