| 914forme |
Aug 26 2017, 05:34 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Well I need a bit of advice.
Out of these three which one would you use, and which is the worse? The worse will be used to make a tool, the best will go in the trans. All three lined up, the stacks will stay with the same letter, I am not playing a shell game here. (IMG:style_emoticons/default/biggrin.gif) So A, B, or C More Detailed pictures of A And B Finally C Thank you (IMG:style_emoticons/default/beer.gif) Attached thumbnail(s) |
| 76-914 |
Aug 26 2017, 05:54 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'd say A except I can't get a good look at C because the pic is a little blurry. (IMG:style_emoticons/default/beerchug.gif)
| 914forme |
Aug 26 2017, 06:36 PM
Sir Andy school of photography (IMG:style_emoticons/default/blink.gif) Did I mention I was counting gear teeth all day
| dangrouche |
Aug 26 2017, 07:46 PM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I believe Dr Evil would say the sharpest and crispest teeth. I dont like "B" selection.
After checking for the sharpest teeth, then see how it snaps together onto a syncro. I would like the snuggest fit. This would be my strategy to see that there is plenty of meat on the walls of the ring gear. |
| adolimpio |
Aug 26 2017, 08:08 PM
Art ![]() ![]() Group: Members Posts: 183 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States
Really need a better picture of the teeth on C
| oldie914 |
Aug 27 2017, 05:53 AM
Member ![]() ![]() Group: Members Posts: 119 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
I recommend you compare your 1st gear syncro teeth to the teeth on a 4th/5th shift sleeve. The 4th/5th doesn't wear much and provides a baseline.
The syncro teeth should be sharp, not rounded. You also need to look at rails behind the teeth to make sure they make a smooth compression of the syncro ring as the gear engages. Sometimes they will wear and metal is smeared off to side; look for sharp edges. I once rebuilt a transmission that had so much metal displaced that 1st gear was blocked. That said, all 3 of your sleeves look pretty good even though it is hard to tell from pictures. A seems to be the best. |
Lo-Fi Version | Time is now: 16th April 2026 - 06:27 PM |
