914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I had to take off my rocker panels. The screws on the passenger side were impossible to screw off. I tried: liquid wrench, screwdriver, screwdriver with wrench, screwdriver with impact wrench (stripped slot on heads), vise grips, bolt removers (with impact wrench), hammer (tapped screws to see if I could loosen the rust), screw extractor (broke 2 drill bits and 2 extractors) and torch. Finally gave up and used a cut-off wheel to cut the heads off.
There are bolt threads sticking out of the holes. I have sprayed them with more Liquid Wrench. Any ideas on how to remove these? I'd like to put screws back in the same holes. I got hex head bolts instead of those infernal cheeseheads. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
I had to take off my rocker panels. The screws on the passenger side were impossible to screw off. I tried: liquid wrench, screwdriver, screwdriver with wrench, screwdriver with impact wrench (stripped slot on heads), vise grips, bolt removers (with impact wrench), hammer (tapped screws to see if I could loosen the rust), screw extractor (broke 2 drill bits and 2 extractors) and torch. Finally gave up and used a cut-off wheel to cut the heads off. There are bolt threads sticking out of the holes. I have sprayed them with more Liquid Wrench. Any ideas on how to remove these? I'd like to put screws back in the same holes. I got hex head bolts instead of those infernal cheeseheads. Heat them up till they are glowing red and use vice grips. If no luck you will have to drill it out. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Weld a nut onto them. The heat should help break the bonds that hold the bolt in, and you'll have a nice larger area to apply pressure to when you put a wrench on it.
--DD |
914 RZ-1 |
Weld a nut onto them. The heat should help break the bonds that hold the bolt in, and you'll have a nice larger area to apply pressure to when you put a wrench on it. --DD Good idea, now I just need to find someone who can weld them! (IMG:style_emoticons/default/smile.gif) Do you think a local shop would do it? I might also have a friend of a friend I could ask. Any idea on what I'd pay someone? I have some holes in the rockers that need patching; maybe I'll have them do the bolts, then see if they can do the holes... (IMG:style_emoticons/default/idea.gif) |
914 RZ-1 |
[/quote] Do I put the vice grips on them while they are still glowing red? I'm also concerned about catching the car on fire! I'm thinking the undercoating might catch. Am I wrong? |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,848 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Just have a squirt bottle ready
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Heat till red. Touch an old candle to the threads as it cools. The wax will wick down without evaporating like penetrating fluid. Use vice grips when cool (contracts). Try to tighten a tiny bit before you loosen. This will usually break it free.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,031 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Heat till red. Touch an old candle to the threads as it cools. The wax will wick down without evaporating like penetrating fluid. Use vice grips when cool (contracts). Try to tighten a tiny bit before you loosen. This will usually break it free. (IMG:style_emoticons/default/agree.gif) Work they back and forth after the heat treatment. |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
...........leave in garage, set house on fire, then ........... ok, just fooling (IMG:style_emoticons/default/bootyshake.gif)
DM_2000 |
Member ![]() ![]() Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None ![]() |
When removing rusted bolts it is critical not to turn them too far in one direction as that puts too much stress on the bolt ( twisting it off ) or nut ( breaking the welds off ). Just work the bolt back and forth to wear out the rust.
I'd use a _new_ pair of real vise grips to grab what is left. A new pair will have sharp square jaws rather than worn ones found on used ones. Liquid Wrench or other penetrant is fine, WD-40 is a miserable lubricant is is worthless. If you heat the bolt, it will expand locking tighter in the nut so let it cool fully before attempting removal. Bolt extractors are not as strong as the actual bolt, they mostly are for when a head is damaged but the threads are free. Bolt extractors are much harder than the bolt so drilling out a broken one is effectively impossible. |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Post a photo of the "holes that need to be patched".
There could be corrosion inside the long, making removal of the screws impossible. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Drill out and retap. No one will ever know.
Lo-Fi Version | Time is now: 6th July 2025 - 04:26 PM |
