> Adjusting Idle Help, Low idle after warming up - '73
vesnyder
post May 20 2005, 12:34 PM
Thought it would be obvious, but cannot find an easy way to adjust the idle on a '73 with D-Jet? It runs fine until it warms up, then it idels at about 100 RPM - when it stays running?
Thanks
SLITS
post May 20 2005, 01:08 PM
"This Utah shit is HARSH!"
1st....Buy a Haynes Manual (cheap).
2nd...there is a idle screw on the throttle body (location depends on whether you have a 1.7 or 2.0). This is used to adjust the idle on a fully warmed up engine (the AAR has closed and is no longer supplying additional air)
3rd....on your ECU you will have an idle mixture knob...intially set it midrange.
4th.....Check your timing and the rest of the ignition settings. (see #1 above)
5th....Check your fuel pressure (see #1 above)
6th....Check the valve adjustment (#1)
Bleyseng
post May 20 2005, 02:15 PM
Aircooled Baby!
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
#1 problem is that guys adjust the idle speed with the AAR valve partway open, the engine only warm. Engine heats up to operating temp and the AAR valve closes and Bingo! idle speed is at 300 rpms. Huh (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
You can just plug the AAR valve hose and then set it...but thats cheating. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
redshift
post May 20 2005, 03:04 PM
Bless the Hell out of you!
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
But it will tell you if you have a GOOD AAR or not!
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
M
- Lo-Fi Version Time is now: 16th June 2024 - 09:43 PM
