right 70-74 engine air guide plate, joins our right ones |
dr914@autoatlanta.com |
Oct 18 2017, 01:34 PM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
We are stamping the right 70-74 engine to heat exchanger air guide plate. This is the plate that shields the clutch and speedo cables from the hot engine, as well as assists in directing the cooling air over the engine. A much needed part, long discontinued by the factory, and often left off by the mechanic replacing your clutch or speedo cable! This joins the left air guide plate already in stock. Part number b022119355
Lo-Fi Version | Time is now: 6th June 2024 - 01:27 PM |
