V8 water pump, who made this? |
sean_v8_914 |
May 29 2005, 10:06 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
fftdutu
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:07 AM
fghjd
Attached image(s) |
sean_v8_914 |
gfchgf
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:09 AM
cghgf
Attached image(s) |
sean_v8_914 |
ghk
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:10 AM
jk,hg
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:11 AM
check out this engine bar
Attached image(s) |
sean_v8_914 |
fdh
Attached image(s) |
ArtechnikA |
May 29 2005, 10:13 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Rube Goldberg?
SLITS |
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Since you didn't provide a good shot of the pump itself, I can't ask our waterpump expert what pump it is.
It looks similar to some marine setups I have seen, but the aluminum throws me as most of them were cast iron (disintegrate slower in salt water than aluminum). Answer on Tuesday if no one else knows. |
sean_v8_914 |
here's a Renegade pump. teh tolerances between the pump impeller and teh housing are very tight
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:15 AM
is this also big block Chrysler?
the impeller blades are only 2/3 the dia of the inside cavity of the housing Attached image(s) |
sean_v8_914 |
May 29 2005, 10:17 AM
it has less blades than the renegade
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:23 AM
gfxhgfh
Attached image(s) |
sean_v8_914 |
May 29 2005, 10:24 AM
fxh
Attached image(s) |
SLITS |
May 29 2005, 10:38 AM
Well, MJM Engineering doesn't seem to exist on the net, 'cept for a company of design engineers, but on further search:
M J M Auto Parts Inc Marine Exhaust Systems of Al Buhl Fairhope Turbochargers- New & Rebuilt Marine Engine Components The baffle on the back of the impeller blades is designed to reduce the cavitation (water bypass) of the impeller blades, hence the less critical distance between the impeller blades and back housing. |
BIGKAT_83 |
May 29 2005, 10:39 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I'm with Slits..
That is a marine pump that why the impeeler is so small for the housing a boat does not need the flow of a car because of the constant supply of cool water. I've seen some of the aluminum housings used on inboard boats that looked just like that. Bob |
JB 914 |
May 29 2005, 11:16 AM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
Skline just replaced his and i think he said it was a Chrysler 440 (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
PM him or Steve S (type4parts) |
sean_v8_914 |
May 29 2005, 11:30 AM
the rayco looks like a boat
SLITS |
May 29 2005, 11:51 AM
Joe is correct....The Renegade uses a Chry 440 Big Block pump. Any local FLAPS will have it. While the original had a cast iron impeller, the newer ("G"s..ornamental in manufacture) use a stamped steel impeller...cheap casting, cheap manufacture.
Lo-Fi Version | Time is now: 11th June 2024 - 01:36 PM |
