Best Brakes for stock rims? |
Greg Bell |
May 30 2005, 05:20 PM
Member Group: Members Posts: 137 Joined: 3-May 05 From: Warner Robins, GA Member No.: 4,024 |
Guys,
What are the absolute best brakes that can be shoehorned in the standard Fuchs' 2.0 rims? I currently have 320 fronts and stock rears. The pedal feels awful, but they work. Is there a better set-up for the standard rim? Thanks! |
nebreitling |
May 30 2005, 05:25 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
what you have should stop the car FINE, if everything is in good working order.
check your pads, rotors, MC, brake lines, bleed bleed bleed and you'll stop. |
grantsfo |
May 30 2005, 06:27 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Nathans right. Stock brakes are more than enough to lock up all 4 wheels at speed. Check your calipers, get some good brake fluid, and some high quality pads. I'm running Porter Field R4 pads and they haul the car to a stop pretty quickly. You'll be amazed at the difference in your brakes if they are working properly. Stainless steel brake lines help will also help firm up pedal feel.
Greg Bell |
May 30 2005, 06:49 PM
TravisNeff |
May 30 2005, 08:50 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
If you are using a 17mm MC that may give you quite a bit of extra pedal travel with those BMW calipers up front. A good bleeding can't hurt. Aside from that maybe bracing the MC if it is flexy (gives poor pedal feel). Pad compound.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:58 PM |
