Exhaust stud nuts. 911 vs 914 |
rhodyguy |
Jan 19 2018, 01:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Will they work? Tired of the copper colored ones the Cap'n detested. I've never trusted the torque value due to the ovaled holes and the way they tightened.
mepstein |
Jan 19 2018, 01:21 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Are you talking about the 911 barrel nuts
rhodyguy |
Jan 19 2018, 01:31 PM
I looked at the ones at pelican. I don't understand how the barrel nut versions work using a hex drive.
mepstein |
Jan 19 2018, 02:24 PM
Threaded on one end, hex drive on other end. I don't think the exhaust studs have enough clearance around them to fit the barrel nuts. I use the 12mm copper colored nuts on a 914. Gives you more room to work than a 13mm.
914Sixer |
Jan 19 2018, 04:56 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I just put some side by side. Diameter is the same because the 914 has a flange and the 911 does not. Also the 911 would be easier to tighten because no socket required. Problem I am seeing is the 911 nuts is they spin up freely and probably will come off just as quick. The factory 914 nut has a coil inside that grabs the stud.
Amphicar770 |
Jan 19 2018, 05:14 PM
Senior Member Group: Members Posts: 1,198 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I tried the 911 nuts and yes, they came loose. Went back to or original style.
iankarr |
Jan 19 2018, 05:52 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I also tried the barrel nuts. Needed washers to space them off the flange and, yes...they came loose.
gereed75 |
Jan 19 2018, 09:08 PM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
You guys are scaring me. I used the barrel nuts. Can’t remember but I want to say I use split locks on them?? With the stock HE’s there is one stud where you can’t get the socket on there. That one got a nut.
Thought it was an “upgrade”. Hope the stay tight! |
mepstein |
Jan 19 2018, 09:17 PM
You guys are scaring me. I used the barrel nuts. Can’t remember but I want to say I use split locks on them?? With the stock HE’s there is one stud where you can’t get the socket on there. That one got a nut. Thought it was an “upgrade”. Hope the stay tight! I used barrel nuts on my MB911 heat exchangers, except the one that needs a regular nut. Barrel nuts are standard on many 911 heat exchangers and used on 914-6 HE's. That's why Ben duplicated the access tubes on his product. |
toolguy |
Jan 19 2018, 09:46 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The barrel nuts [ with allen heads] are used on 911 and 914-6 to get thru the holes in the heat exchanger. . If you have to use washers, the studs are too long. . The 12 mm copper nuts are used on the other studs because of limited wrench clearance between exhaust header and outside of wrench. . the front nut on the passenger side of a 914'6 is a real bitch. . you can see it and almost touch it. . I have a special bent up wrench just for that one stud. .
mepstein |
Jan 19 2018, 10:04 PM
We call it an SSI wrench but real name is distributor wrench.
Attached image(s) |
Larmo63 |
Jan 19 2018, 10:34 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I used the 12mm nuts, I've checked and re-checked them, no exhaust leaks ever.
914Sixer |
Jan 20 2018, 07:29 AM
I think I have found some replacements for the NLA factory nuts. I ordered some. Not cheap but better than the $18 each for the factory nuts. Made of titanium with locking threads.
Attached image(s) |
mepstein |
Jan 20 2018, 07:36 AM
bdstone914 |
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I think I have found some replacements for the NLA factory nuts. I ordered some. Not cheap but better than the $18 each for the factory nuts. Made of titanium with locking threads. How costly are those made out of titanium ? How about these ? https://www.mcmaster.com/#95108a102/=1b7iz3e $9.00/100 I bought a bunch of these SS flanged nuts that might be an option on heat exchangers Bruce Attached thumbnail(s) |
rhodyguy |
Jan 20 2018, 08:34 AM
Being stainless, do you think there might be an issue with the steel studs? I tried using SS hardware on the muffler to heat exchanger connection one time. Didn't work out so well. Perhaps the black phosphate ones might be better suited for this application?
mepstein |
Jan 20 2018, 08:49 AM
I like the height of the ti bolts. Theres a lot of bolt to grab on to.
CMONNETT |
Jan 20 2018, 09:30 AM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
914Sixer |
Jan 20 2018, 09:50 AM
EBAY 161892735045 3 to bag. 10.99 shipped
rhodyguy |
Jan 20 2018, 09:54 AM
eBay link doesn't open on the tablet. It wants to dial that #. I'll look it up manually.
Lo-Fi Version | Time is now: 11th June 2024 - 12:28 AM |
