Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Got the cigarette lighter out, but how do the other switches come off? Unscrew the pull and then somehow remove the plate that is external OR does the switch pull out towards the interior?
I should know this from the 911 and 928 but... |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The switches pull out the back but you need a special wrench to unscrew the front clamp ring. Or use a larger coin to fit in the two grooves.
(IMG:style_emoticons/default/smash.gif) |
Tdskip |
The switches pull out the back but you need a special wrench to unscrew the front clamp ring. Or use a larger coin to fit in the two grooves. (IMG:style_emoticons/default/smash.gif) Ah, got it. Thanks Sir, er Andy, wr Sir Andy. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I have used a pair of needle-nose pliers in the holes, or in the slot across the center of the "escutcheon" (which is what the manual calls that flat nut). Once the escutcheon is loose, you can spin it off with your fingers, and then the switch body comes out toward the inside of the dash.
--DD |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,774 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
It helps to 'rock' and the switch from behind to break the escutcheon loose on the front. |
Lo-Fi Version | Time is now: 9th July 2025 - 01:22 PM |
