more cht questions |
kevmac |
Jun 7 2005, 08:03 PM
Newbie Group: Members Posts: 5 Joined: 30-May 05 From: franklin, ma Member No.: 4,167 |
the wire connected to the cht has a resistor looking thing(mini hotdog) that it connects onto, in line. is this "hotdog" neccesary. if so, where can i find it? - the wire is broken at the end of the hot dog.
thanks. kev. |
redshift |
Jun 7 2005, 08:16 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
..that thing is a brown protective thingy, over the paddle connector..
Use good shrink wrap, after you terminate a nice clean end on that wire, then zip tie the wire to anything that holds it off of the tin, and jiggly hot intake crap. M |
JeffBowlsby |
Jun 7 2005, 11:11 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Dont listen to Miles...he thinks people actually listen to him.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
You must have a 73 2.0. Its a ballast resistor, and yes you need it. Your car should not run of the CHT is disconnected (it will be too rich). Its 270 ohm resistor. I may have n OEM one in my stash to offer, but you can replace it with another resistor of equal value...not sure of the wattage rating it may need. |
redshift |
Jun 7 2005, 11:46 PM
Bleyseng |
Jun 8 2005, 06:47 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
You can buy a 270 ohm resistor at Radio Shack for $1.99 and install spadeconnectors on it. Put some shrink tubing on it and then do what Miles said to keep it from bouncing around.......
This is only for 73 2.0l engines with matching ECU and 037 MPS's. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:13 AM |
