| billh1963 |
May 3 2018, 07:17 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
My realtor has a lift in some commercial they want to get rid of. I can have it for free. The lift has a hydraulic problem that would need to be addressed.
I haven't seen one like this....worth having? I would like to have one for my Porsche's ![]() ![]() ![]() ![]() |
| worn |
May 3 2018, 07:24 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
My realtor has a lift in some commercial they want to get rid of. I can have it for free. The lift has a hydraulic problem that would need to be addressed. I haven't seen one like this....worth having? I would like to have one for my Does it only work with the ramps? That is, it looks more like a 4 post lift in function. Good for a lot of things, but not as good for wheel suspension stuff. I have a free lift that suits my needs, but sometimes wonder if it was worth it. It meant I got a lift, but not the one I would have chosen |
| billh1963 |
May 3 2018, 07:28 PM
My realtor has a lift in some commercial they want to get rid of. I can have it for free. The lift has a hydraulic problem that would need to be addressed. I haven't seen one like this....worth having? I would like to have one for my Does it only work with the ramps? That is, it looks more like a 4 post lift in function. Good for a lot of things, but not as good for wheel suspension stuff. I have a free lift that suits my needs, but sometimes wonder if it was worth it. It meant I got a lift, but not the one I would have chosen I like the idea of a regular two post lift for doing suspension work, dropping engines, etc. My dilemma is as you stated....is this the lift I would choose? Since it needs work, do I put money in it even though I'm not sure it's what I want/need? |
| mepstein |
May 3 2018, 07:38 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
That looks like a big lift.
Between takedown, set up and repair, you might not be far off a new one. |
| ledfoot |
May 3 2018, 08:19 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 14-February 06 From: Dayton,OH Member No.: 5,581 Region Association: None
That appears to be an alignment lift. It will have four fold down post to level the rack. Some have adjustable pneumatic lift pad that mount in the center to lift the car.
| theer |
May 3 2018, 08:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
(IMG:style_emoticons/default/agree.gif) Alignment lift. Might even have a trolley lift between the ramps.
Free is good... usually. |
| dakotaewing |
May 3 2018, 08:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region
Looks like it has been modified for the alignment rack - That is a 2 post lift but it appears the original 4 arms are missing -
Are they at the shop? Look at the manufacturers website under the 7000lb lifts - http://www.forwardlift.com/Support/Manuals-archive/ |
| SirAndy |
May 3 2018, 08:59 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This looks like complete overkill for a 914 plus you can't work on the suspension at all.
I'd pass ... (IMG:style_emoticons/default/shades.gif) |
| rhodyguy |
May 4 2018, 05:51 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Useless for a valve adj.
| dcheek |
May 4 2018, 06:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
That lift looks REALLY HEAVY.
I would just go with the Greg's Equipment lift, the Atlas I've had mine for 4 years, works great. ![]() |
| My 914 |
May 4 2018, 06:35 AM
Casual Member ![]() ![]() ![]() Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
It will be costly and time consuming to move. Maybe that's why they're giving it away.
| kahluver |
May 4 2018, 07:33 AM
Newbie ![]() Group: Members Posts: 49 Joined: 3-October 14 From: Huntington Beach, ca Member No.: 17,973 Region Association: Southern California |
Looks like it has been modified for the alignment rack - That is a 2 post lift but it appears the original 4 arms are missing - Are they at the shop? Look at the manufacturers website under the 7000lb lifts - http://www.forwardlift.com/Support/Manuals-archive/ Moving the lift is probably the biggest expense. If you want a 2 post lift it could be worthwhile as I don't think converting it back from the alighnment rack to a 2 post is tough. If the arms are available they should just bolt on. A "hydraulic problem" doesn't sound that difficult to fix either. |
| bulitt |
May 4 2018, 07:48 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Thats a big-ass heavy lift (IMG:style_emoticons/default/blink.gif)
They will need to load it on a trailer. At your end you will need to make sure the concrete floor is thick enough and it fits under the ceiling. Then you will need to install the floor bolts. Drill/epoxy? Then lift it one piece at a time,position and bolt down Run the Electrical Install the ramps. If it is a hydraulic seal leaking you will have to either replace it yourself or have the cylinder rebuilt. Or it may need a new pump? And it should be inspected by someone that can see issues...refer to AA thread about car falling off lift. Do you own a tractor? I would bet each ramp weighs close to 1000lbs Forklift rental is @350 a day and 150 delivery... Personally there are better alternatives... IMHO. This may fit the Bill, Bill. 1300$ https://www.quickjack.com/car-lift-systems/...e-car-lift.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.quickjack.com-13632-1525441724.1.jpg) |
| billh1963 |
May 4 2018, 08:11 AM
I already own a Quickjack. This just dropped in my lap so I was wondering some opinions on whether or not it was worth the effort. I do want a two post lift and thought this might b a good solution.
Equipment isn't an issue...I have three tractors, flatbed truck, a couple deck over trailers, have a forklift I can borrow, etc. The real concern is cost of overhaul (is it worth the effort) and utility I'll take this opportunity to show off my tractors. I really like them (IMG:style_emoticons/default/wub.gif) Attached thumbnail(s) |
| rhodyguy |
May 4 2018, 08:19 AM
Front end loaders are a thing of beauty. (IMG:style_emoticons/default/wub.gif)
| DRPHIL914 |
May 4 2018, 08:33 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
What?/?? (IMG:style_emoticons/default/WTF.gif) bill no Porsche tractor?? (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/lol-2.gif)
| DRPHIL914 |
May 4 2018, 08:36 AM
kidding aside, how much for the building, I assume its for sale?? bet better if someone would buy the building with the lift in it that wanted a lift and could just fix it and leave it there -
(is the building in NW Charolette NC area?) |
| billh1963 |
May 4 2018, 08:46 AM
The building isn't for sale. It was just purchased and the new owner wants it gone.
I'm going to pass on it. If anyone wants the contact info send me a PM. Lift is in Orangeburg, SC |
| mepstein |
May 4 2018, 08:49 AM
(IMG:style_emoticons/default/agree.gif) I don't have one but luckily my neighbor does. As well as this beauty. Attached image(s)
| bulitt |
May 4 2018, 10:24 AM
Yup, love my tractor...
Lo-Fi Version | Time is now: 2nd April 2026 - 12:41 PM |
