Tunnel Shift Rod Removal, Engine in... |
Montreal914 |
May 6 2018, 04:41 PM
Senior Member Group: Members Posts: 1,588 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Is there a way to remove the tunnel shift rod (side shift car) without dropping the engine? (IMG:style_emoticons/default/blink.gif)
I'm thinking of actually jacking up the engine a little in hope it will go through the engine cross member shift rod hole... Open to suggestions (IMG:style_emoticons/default/beerchug.gif) |
worn |
May 6 2018, 06:24 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Is there a way to remove the tunnel shift rod (side shift car) without dropping the engine? (IMG:style_emoticons/default/blink.gif) I'm thinking of actually jacking up the engine a little in hope it will go through the engine cross member shift rod hole... Open to suggestions (IMG:style_emoticons/default/beerchug.gif) Have you tried removing the end at the transmission? |
rgalla9146 |
May 6 2018, 06:27 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Based on no experience, just considering anatomy I think you can.
You may have to support the engine and remove the front engine cross bar. |
Montreal914 |
May 6 2018, 10:11 PM
So I ended up removing the four 8mm screws of the two ~3" mounts that holds the engine cross bar to the body, and loosened up the two rear gearbox large mounting bolts.
Using my floor jack under the engine cross bar, I lifted it ~1" and shifted it a little towards the passenger side. That was just enough to get it out and slide the modified (IMG:style_emoticons/default/idea.gif) one in. Moving on to the next step of my shifter linkage update. Modification thread to follow. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 09:10 AM |
