NEEDED- source for rear caliper spacer blocks, Brakes: |
TRE Cup |
Jun 13 2005, 02:05 PM
Member Group: Members Posts: 80 Joined: 1-March 05 From: North Hollywood, CA Member No.: 3,690 |
We are going to install a set of rear 911 vented rotors on a 2.0. So we need a source on the spacer blocks and seals to "widen" the original rear calipers
can anyone help? Thanks! dave |
Jeroen |
Jun 13 2005, 04:57 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
TRE Cup |
Oct 14 2005, 03:19 PM
eric shea came through for us
thanks dave |
Eric_Shea |
Oct 15 2005, 12:50 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Glad they worked out Dave,
These are for 72 and later calipers gang. Sourcing the 7mm hardware in the sizes needed for the old style proved too expensive. Rotor spacers are for 4 or 5 lug (if you wanted the vented rotors on a 4-lug car you could drill the rotor to match) Remaining kits will probably be made into V-Calipers at $395.00 a pair. Finished in Silver zinc. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 03:42 PM |
