My 2.0 Liter engine has running issues, my 75 D jet engine will sometimes buck or stop on the road. |
dralf |
Oct 9 2018, 01:00 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
My 75 Porsche with the original D Jet has started to occasionally buck or stop when on the road. Over the years I have replaced the wiring harness, the Maps sensor, voltage regulator, coil, trigger points.. and a few other items. I checked the dwell a month ago and it indicated the points were off, so I changed them. This seemed to solve the problem for a few short trips, however, the issue is now back with a vengeance. I limped home today with numerous events on the interstate when the engine just started to loose power and the reves would drop and if I did not down shift and get the reves to 4000+ or pump the gas the engine would die completely. Thankfully once dead it would start and if I kept the reves high I could drive a bit further. Once home I checked the dwell and it is at 50 which I recall is at the upper range but should not be the culprit. I do not feel vacuum leaks nor any obvious loose connection. Only thing I wonder about is that I noticed that the voltage going from the coil to the points is 6 volts, is this correct ?
Any suggestions as to where to troubleshoot would be appreciated. I will be checking out my fuel filter since I think issues with it could cause the engine to die yet restart easily. |
mepstein |
Oct 9 2018, 01:14 PM
914-6 GT in waiting Group: Members Posts: 19,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had a bucking issue on mine that did not go away until I changed the coil.
I had previously changed the engine wire harness and ecu, all new gas lines and filters, got injectors cleaned and cleaned and reclocked TPS. |
DRPHIL914 |
Oct 9 2018, 01:21 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i agree with Mark this is a possibility, but bucking issue can be caused by a number of things I have had a few of these- bad TPS, FI grounds shorting out or coming loose, or other grounds not making good contact.
Test the coil or wires , and check the tps , just unplug it and see if there is a change or improvement. The last time I had really back bucking it was the worn TPS board, but the time before that was the coil. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:11 PM |
