Need some quick help, Accelerator to carb linkage |
ericoneal |
Nov 19 2018, 04:33 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
mobymutt |
Nov 19 2018, 08:23 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
The stock cable worked on mine. It went straight into the cross-pin. Not sure what that extra piece is that you show currently stuck into the cross-pin, I think it just needs to be removed.
adolimpio |
Nov 19 2018, 08:50 PM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
This is the best picture I could find.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1072748822.jpg) |
ericoneal |
Nov 19 2018, 09:36 PM
I think your're right, but the set screw to remove the extra piece (old ferrule?) is completely rounded out. Also, if I did get it removed, I still would not be able to pass the cable through the next piece (the cylinder with the set screw) unless there is not ferrule. Very odd setup by previous owner.
I'm thinking of leaving it as is, snipping the ferrule off of my new cable and running the cable through the cylinder piece and calling it a day. The stock cable worked on mine. It went straight into the cross-pin. Not sure what that extra piece is that you show currently stuck into the cross-pin, I think it just needs to be removed. |
IronHillRestorations |
Nov 20 2018, 08:16 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've been recommending the CSP center pull bell crank linkage, which is far superior to any cross bar, and not too expensive.
http://www2.cip1.com/ProductDetails.asp?Pr...C31-129-941-400 You still have to come up with a cable bracket though. |
mobymutt |
Nov 20 2018, 09:04 AM
I've been recommending the CSP center pull bell crank linkage, which is far superior to any cross bar, and not too expensive. http://www2.cip1.com/ProductDetails.asp?Pr...C31-129-941-400 You still have to come up with a cable bracket though. That's what I did. Mark @ Original Customs can sell you a cable bracket for it. |
Chi-town |
Nov 20 2018, 10:31 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
A cross bar set up isn't that bad if it's set up correctly.
Every set up has play in it, if you take the time to make sure everything is tight and aligned correctly it will work just fine. After looking at my parts car that has the same linkage as your car the ferrule on the end of the cable is intact and held into the linkage. I'll snap a few pics in a sec. |
ericoneal |
Nov 20 2018, 10:44 AM
Thanks!
I'd like to stick with what I have because it has worked great so far. I pulled the engine a couple weeks ago and disconnected everything except the accelerator cable. snap! Doh! Ran the new cable to the pedal last night, what a job that was.. A cross bar set up isn't that bad if it's set up correctly. Every set up has play in it, if you take the time to make sure everything is tight and aligned correctly it will work just fine. After looking at my parts car that has the same linkage as your car the ferrule on the end of the cable is intact and held into the linkage. I'll snap a few pics in a sec. |
Nogoodwithusernames |
Nov 20 2018, 11:13 AM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
The funky looking thing that was attached to the end of your old cable is just an extender, ditch that and if you need a new barrel clamp pick some up from your FLAPS. Here's one from Air-cooled.net
http://vwparts.aircooled.net/Barrel-Clamp-...arrel-clamp.htm |
Chi-town |
Nov 20 2018, 11:22 AM
ericoneal |
Nov 20 2018, 12:13 PM
Thanks guys. I think what I am seeing is the old extender still connected to the linkage with the stripped out set screw. I'm just going to clip off the new extender and run the cable though the barrel adjuster and clamp it down. The new cable will not fit through the barrel with the extender on it. (or by running it the opposite way due to the plastic cable housing.)
Lo-Fi Version | Time is now: 9th June 2024 - 01:07 PM |
