Trim Assembly Question, Having trouble figuring out how it goes together |
Highland |
Nov 22 2018, 07:51 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Is this picture below correct or do I have it backwards?
boxstr |
Nov 22 2018, 07:57 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
The one in the pic should be on the other side and the one on the other side should probably be on that side.
Craig at CAMP |
914Sixer |
Nov 23 2018, 10:39 AM
914 Guru Group: Members Posts: 8,898 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Need to put side and top vinyl on before installing any chrome.
Highland |
Nov 23 2018, 10:49 AM
I was planning on no vinyl.
Tried swapping everything around and every which way and the configuration shown seems to be the only way everything lays flat. The trim is a little bit loose, but I assume that's cause I'm missing the vinyl. |
Tom_T |
Nov 23 2018, 10:59 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
The one in the pic should be on the other side and the one on the other side should probably be on that side. Craig at CAMP Craig means to swap it to the pass side, & the other to driver side, unless you got 2 of the same side parts by mistake. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:18 PM |
