Deck Height and Valve Relief, What would you do? |
BeatNavy |
Mar 4 2019, 06:44 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
While I wait (seemingly forever) for back-ordered rocker shims to arrive from aircooled, I keep debating in my head which way to go on deck height on a 2056 rebuild I am doing:
CC volume is 59.8 (calculated by Len Hoffman) Raby 9950 (FI) cam JE Pistons with valve relief Deck height w/o any barrel shims is .032. That gives me a CR of 8.6, assuming the valve relief adds about 2 cc's to CC volume. Adding a .010 shim puts me just shy of 8.4 CR with a deck height of .042. .042 deck height is safer. Pretty sure I wouldn't go .032 deck height with flat tops, but does the valve relief give me enough "safety?" This is my first Type 4 rebuild, so maybe I should go conservative? Am I crazy considering going less than .035? I've done the "clay test" with deck height at .042, and there's no issue there. What would you do? |
r_towle |
Mar 4 2019, 06:49 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Go with the shim
sixnotfour |
Mar 4 2019, 06:53 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
valve relief cuts no mystery...find a local shop..you can split the cr 70/30
BeatNavy |
Mar 4 2019, 07:03 PM
So I should probably add: I did go to my "local" machinist (about an hour a way) and had him cut .035 off the jugs a few weeks back. I should have had him take a bit more, but I didn't think it all the way through -- that's my fault. Having him do additional work is a couple of 2 hour trips, $100 in services, and, likely, 2 to 3 weeks waiting. None of that is a deal breaker, but just trying to determine my options.
So I guess the straightforward question is: what is safe/acceptable deck height with valve relief? Still .040? .035? Thanks for the input, fellas. |
sixnotfour |
Mar 4 2019, 07:06 PM
ya shims
BeatNavy |
Mar 4 2019, 07:10 PM
VaccaRabite |
Mar 5 2019, 09:48 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The old rule of thumb was that .040 was the smallest safe deck height. Tighter then that you needed to measure and be SURE.
Some guys would measure by putting a little lump pf clay/play-doh on the piston and rotating the engine by hand. Then pulling the head off and looking at the clay to see how much room they had after it was squished by the valve. Are you running a head gasket? Zach |
BeatNavy |
Mar 5 2019, 10:01 AM
Thanks, Zach. No head gasket. I did the play-doh with the barrel ship installed and deck height of 042. No issues. Just wondering if .032 was too close even with valve relief. I should have planned it a little better ahead of time with the machinist, but it should still be all good.
Bleyseng |
Mar 5 2019, 10:10 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Add the shim.....
ChrisFoley |
Mar 5 2019, 10:13 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I doubt you need valve reliefs with the FI camshaft either way.
BeatNavy |
Mar 5 2019, 10:22 AM
Yeah, live and learn (which is a large part of what this hobby is for me). If the worst outcome is I left roughly .1 CR on the table then I will still be pretty happy with my first Type 4 build (IMG:style_emoticons/default/smile.gif)
Mark Henry |
Mar 5 2019, 10:27 AM
Piston rocks at TDC, .040" is my minimum.
That cam I don't know the specs, but you said FI, so you don't need pockets. |
Olympic 914 |
Mar 5 2019, 11:20 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
McMark |
Mar 7 2019, 01:42 PM
BeatNavy |
Mar 7 2019, 07:21 PM
... had him cut .035 off the jugs... Off the top or the bottom? If the top, make sure the heads don't hit the top cylinder fin. Off of the bottom... ....and, I went out and purchased a set of Keith Black flat top pistons. I'm hoping it doesn't radically change existing deck height, but we'll see. I guess I'm willing to start from scratch to get closer to 8.6 CR after all. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:16 PM |
