914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Have you considered using small patches of heavy duty velcro in the corners? It shouldn't take much to secure the cover and would still allow removal without unbolting anything. Just a thought...
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
I don't get it, it has worked for 50+ years and now you worry (IMG:style_emoticons/default/confused24.gif)
Attached image(s) ![]() |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
It's not going anywhere in a street car...unless you are upside down If in a track car....it and the spare are weight....remove them The carpet actually helps it stay in place and not shift around |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,491 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
How about a few rubber blocks fastened to the bottom that press into the rim.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Is this real? I've never heard of this problem. Just tank it or remove it. Racers obviously don't carry them. What is your issue??? And pooleeeezzzzzz stop with the random bolts.
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,905 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Duct tape
914 RZ-1 |
I have an industrial design background so I'm often finding ways to make improvements. Not sure why this wasn't done originally; maybe it was a cost consideration. Here is the finished product:
![]() It rests on the spare. I have a bolt going thru one of the bolt holes on the tire thru an aluminum plate bolted to the back of the cover. The wing nut tightens it down. I carry a tool box so the red straps are for securing the tool box to the cover. It works, so I thought I'd share. |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,146 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Overkill for a solution that didn't have a problem. Just because you can doesn't mean you should.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,813 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I have an industrial design background so I'm often finding ways to make improvements. Not sure why this wasn't done originally; maybe it was a cost consideration. Here is the finished product: ![]() It rests on the spare. I have a bolt going thru one of the bolt holes on the tire thru an aluminum plate bolted to the back of the cover. The wing nut tightens it down. I carry a tool box so the red straps are for securing the tool box to the cover. It works, so I thought I'd share. Nice job , (IMG:style_emoticons/default/smile.gif) |
jim_hoyland |
Years ago, I made a cooler to fit in the front trunk: used an A/C cover from a 914, cut a hole in the spare tire cover board, and ran a drain line out the bottom. There was always a cold-one up front... (IMG:style_emoticons/default/beer3.gif)
Attached image(s) ![]() ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,909 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
post a pic of your trunk floor...there shoiuld be a very adequate factory mount...unless your 914 had AC..
914 RZ-1 |
@jim_hoyland
Thanks, I appreciate that! How long did your cooler keep stuff cold? (IMG:style_emoticons/default/beerchug.gif) |
914 RZ-1 |
post a pic of your trunk floor...there shoiuld be a very adequate factory mount...unless your 914 had AC.. The factory mount holds the spare tire. I made something to hold the cover to the spare. I wanted them separate so when I unbolted the bolt that holds the cover down, the spare would still be attached. |
Chris914n6 |
That turned out nice.
Also explains the confusion. The factory cover fits tighter and is carpeted. Might flop on speed bumps but that's about it. |
jim_hoyland |
@jim_hoyland Thanks, I appreciate that! How long did your cooler keep stuff cold? (IMG:style_emoticons/default/beerchug.gif) All day. I used it for trips up the Central Coast several times. Going to part with it since I make fewer trips in the 914. |
Lo-Fi Version | Time is now: 12th July 2025 - 11:21 AM |
