| twistedstang |
Mar 14 2019, 01:48 PM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
| yeahmag |
Mar 14 2019, 02:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I use a flat washer and non-locking 8mm nut torqued to spec.
| mb911 |
Mar 14 2019, 02:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I use spring washers no split washers.
| sixnotfour |
Mar 14 2019, 03:45 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,365 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
2 900 075 079 02 Hexagon-head bolt 10 914-6
M 8 X 22 3 N 012 241 1 Spring washer 10 914-6 B 8 X 15 4 900 076 025 02 Hexagon nut 10 914-6 M 8 |
| bdstone914 |
Mar 15 2019, 03:19 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,379 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Spring washers are correct. The bolt goes through from the rotor side with the nut and washer against the hub.
Bruce |
| twistedstang |
Mar 15 2019, 05:33 AM
Thanks everyone. I'll be on the hunt today for spring washers.
Lo-Fi Version | Time is now: 15th September 2026 - 04:46 AM |
