> Fog Light relay
luvatenor
post Apr 12 2019, 03:08 PM
I pulled the relay board down but have no clue which relay does what- here is a pic of what I found- which one is the fog light relay? thanksAttached Image
Spoke
post Apr 12 2019, 03:13 PM
Jerry
What year is your 914?
I think it's the one on the end. Look for one with a white/blue wire.
The 2nd one from the left is the high/low beam and the 3rd one from the left is the flasher relay. Not sure about the others.
Mark Henry
post Apr 13 2019, 06:35 AM
that's what I do!
I think it's the far right relay.
'70-'71 914-4 and 914-6: Black wire w/ blue stripe will be plugged into the #58b terminal on the headlight switch, along with a grey wire.
'72-'73: Black wire w/ blue stripe will be plugged into the #56 terminal on the headlight switch, along with a grey wire and a red w/white striped wire.
'74-'76: Black wire w/ blue stripe will be plugged into the #56 terminal on the headlight switch, along with a red w/white striped wire.
- Lo-Fi Version Time is now: 14th September 2026 - 07:54 PM
