alternator options April 2019? |
dflesburg |
Apr 17 2019, 11:03 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
What are the current alternator options for the type 4 these days, the 160amp guy seems to be no longer around.
I know a guy that created a new mount and put a gm alternator on his car. Whats being done? |
malcolm2 |
Apr 17 2019, 11:31 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
My 55 amp one went out last year. I did some research then and found the guy you are talking about. But he was too busy to "build" anymore. I kinda wanted to do the set-up myself, but he would not pass on his propriety (IMG:style_emoticons/default/smile.gif) info. And they were way too expensive. My next thought was to get a 70 amp one that VW used on late 70's campers sent to the great white north. That also failed to develop an alternative. It seems there just were not very many campers sent to Canada.
But just last week a guy in Washington state found my WTB ad on TheSamba and sent me 2 pulleys with fans, pulled from 79 Canadian campers. IIRC this ALT does not use the elbow tube from the TIV cooling fan, so it needs a fan on the pulley. I also remember the need for a larger opening on the ALT front tin. It has been too long. I think I have some threads out there you could search by MALCOLM2. I may look into it again, cause I am building a Bay Window bus that is gonna need an alternator..... |
Rob-O |
Apr 17 2019, 12:48 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I have a 100amp one wire GM alternator on my car. It doesn't allow for the use of the cooling tin in that area, which I don't like. But it works well. I'll see if I can snap a photo of the setup here in the next day or so.
914Sixer |
Apr 18 2019, 05:44 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Seller on Ebay has high output alternators.
saigon71 |
Apr 18 2019, 12:44 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
For stock I wonder if it's worth taking a chance on this one:
https://www.autozone.com/batteries-starting...66988_100967_0# |
Bleyseng |
Apr 18 2019, 01:22 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
My 55 amp one went out last year. I did some research then and found the guy you are talking about. But he was too busy to "build" anymore. I kinda wanted to do the set-up myself, but he would not pass on his propriety (IMG:style_emoticons/default/smile.gif) info. And they were way too expensive. My next thought was to get a 70 amp one that VW used on late 70's campers sent to the great white north. That also failed to develop an alternative. It seems there just were not very many campers sent to Canada. But just last week a guy in Washington state found my WTB ad on TheSamba and sent me 2 pulleys with fans, pulled from 79 Canadian campers. IIRC this ALT does not use the elbow tube from the TIV cooling fan, so it needs a fan on the pulley. I also remember the need for a larger opening on the ALT front tin. It has been too long. I think I have some threads out there you could search by MALCOLM2. I may look into it again, cause I am building a Bay Window bus that is gonna need an alternator..... Yes, it does use a rubber boot from the fan shroud to the back of the Alt. It is different in that it's got a big round end to fit the big round inlet tube on the alt. Several VW places carry the special boot like Busdepot. I have one in my camper and tons of guys are searching for them as they are getting rare just like the fan pulley with the fan on it. Use the late bay Alt tin as it's got a bigger hole for em. |
malcolm2 |
Apr 18 2019, 01:46 PM
For stock I wonder if it's worth taking a chance on this one: https://www.autozone.com/batteries-starting...66988_100967_0# I remember originally buying one from AZ. THat picture looks correct. But the one I bought in 2012 had a wonky rear edge. The tin on the rear did not fit correctly and would not seal. That one looks different, it might work. Get one and see if all the tin fits and the studs on the back don't touch..... Life Time Warranty is nice tho. But the labor to remove is hell. I do remember Cap'n Crusty reeming me a new one tho.... RIP Cap'n |
GregAmy |
Apr 18 2019, 02:06 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That one looks different, it might work. Get one and see if all the tin fits and the studs on the back don't touch..... Life Time Warranty is nice tho. But the labor to remove is hell. Bingo. I just did one a few weeks ago, and hated myself for it. I'd much rather pay extra for a known-good-quality one and avoid having to do it again. I sent mine to some old guy in New Hampshire that apparently knows what he's doing, and paid him $120 to rebuild it. I don't want to do that job again... |
dralf |
May 18 2019, 12:50 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
I am wondering if my Auto Zone unit is also on its' way out. Can anyone tell me how best to check its' performance without having to take it out and run it to Auto zone and tell me it is bad?
IronHillRestorations |
May 18 2019, 01:06 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
For stock, you might try NAPA. My local store can get Bosch remanufactured which have a good warranty.
I have several rebuilt stock alternators that I got from a rebuilder that closed shop. I sell those for $80 plus shipping, outright. TBH though I wouldn't use anything but the Bosch reman. I've got one oddball that I was told to be 90 amp VW, I'll get a pic |
Spoke |
May 18 2019, 02:51 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I am wondering if my Auto Zone unit is also on its' way out. Can anyone tell me how best to check its' performance without having to take it out and run it to Auto zone and tell me it is bad? Start the car and elevate the idle to about 2k RPM. Measure: Battery + to chassis - should be 14V On the plug to the VR, measure: V+ to chassis - should be 14V VF to chassis - should be 3-6V V- to chassis - should be 0.0V Repeat the same measurements with the headlights on. The battery voltage may be 13 to 14V during these tests. |
jim_hoyland |
May 19 2019, 06:47 AM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I am wondering if my Auto Zone unit is also on its' way out. Can anyone tell me how best to check its' performance without having to take it out and run it to Auto zone and tell me it is bad? Measure: On the plug to the VR, measure: V+ to chassis - should be 14V VF to chassis - should be 3-6V V- to chassis - should be 0.0V Would you explain/show exactly how/where these measurements are made, I'd like to try this...I'm not familiar with all the connections outside the plug from the alt to the relay board |
Spoke |
May 19 2019, 07:25 AM
I am wondering if my Auto Zone unit is also on its' way out. Can anyone tell me how best to check its' performance without having to take it out and run it to Auto zone and tell me it is bad? Measure: On the plug to the VR, measure: V+ to chassis - should be 14V VF to chassis - should be 3-6V V- to chassis - should be 0.0V Would you explain/show exactly how/where these measurements are made, I'd like to try this...I'm not familiar with all the connections outside the plug from the alt to the relay board On the plug from the alternator to the VR on the relay board, the 3 wires can be seen looking into the plug. Measuring DC volts, put the positive DMM lead on one of the pins and the negative DMM lead on the chassis ground lug which can be found right behind the relay board. |
cary |
May 19 2019, 07:55 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Left side engine tin, going to relay board. |
jim_hoyland |
May 19 2019, 12:39 PM
Is the above test done with engine running; Any problem unplugging the alt harness if engines running ?
Spoke |
May 19 2019, 01:06 PM
Is the above test done with engine running; Any problem unplugging the alt harness if engines running ? Yes, engine running at about 2k RPM. I would advise against unplugging the alt harness while the engine is running. If you want to change VRs, stop the engine, replace and restart. |
May 24 2019, 03:30 PM
This is the oddball Bosch alternator I have
Attached thumbnail(s) |
mb911 |
May 24 2019, 04:17 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Could a 944 style unit be adapted?
Bleyseng |
May 24 2019, 06:34 PM
This is the oddball Bosch alternator I have Thats the Canadian or Cold weather Baywindow 70amp alt. I have one in my Westy. To fit it in a 914 you just need the special boot from BusDepot so it hooks up to the fan. Came with the pulley that has a fan on it but those are around too. |
May 25 2019, 06:55 AM
This is the oddball Bosch alternator I have Thats the Canadian or Cold weather Baywindow 70amp alt. I have one in my Westy. To fit it in a 914 you just need the special boot from BusDepot so it hooks up to the fan. Came with the pulley that has a fan on it but those are around too. Thanks for ID'ing that Geoff! |
Lo-Fi Version | Time is now: 31st May 2024 - 07:07 PM |
