PC 680 battery adapter. How I did it., No new holes |
Krieger |
May 12 2019, 08:54 AM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
You guys are used to seeing my track car with lots of holes drilled in it. This is for my shiny red 75. I wanted the adapter and battery to bolt in using just the original single bolt. This is what I came up with using scrap I had laying around. I found that 5/8" round tubing makes a tight fit under the end of the battery tray. The rest is 1 and 2".
Krieger |
May 12 2019, 09:02 AM
Painted
Attached thumbnail(s) |
Krieger |
May 12 2019, 09:07 AM
Installed
tygaboy |
914 Guru Group: Members Posts: 5,314 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Makin' stuff! (IMG:style_emoticons/default/aktion035.gif)
Love it. |
Krieger |
May 12 2019, 09:11 AM
With battery. I needed one small 1/8" rubber piece under one of the arms for a tight, no movement fit.
Krieger |
May 12 2019, 09:15 AM
A little bit! I haven't done anything for this car in a couple of years. |
sithot |
May 12 2019, 09:27 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Well done! Keep a proper trickle charger on it. "They" don't mind but you will if you turn the key one day and get "nothing". (IMG:style_emoticons/default/wink.gif)
infraredcalvin |
May 12 2019, 10:23 AM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Nice fit, clean and purposeful!
Lo-Fi Version | Time is now: 10th June 2024 - 08:54 AM |
