| saigon71 |
Jun 8 2019, 05:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
Even in a fine state of tune with no vacuum leaks and the ECU set to full rich, my cars idle would hunt terribly during warm-up (occasionally stalling).
The other problem I have is that on particularly hot days, the car heat-soaks if I shut it down while running an errand. It becomes extreemly difficult to start until it cools off. I'm not talking vapor lock here, definately heat soak. Last year it left me stranded in a cemetary following a funeral in the blistering sun. Twice, heat soak has caused my car to not start while on a date, which is a little embarrassing in your 40's. (IMG:style_emoticons/default/dry.gif) I drive this car a lot and needed to find a permanent solution. I studied this thread closely: http://www.914world.com/bbs2/index.php?showtopic=298261 After considering a bunch of alternatives, I felt the best all around fix was indeed a parmanent trim knob in the passenger compartment. Based on the testing and research by PBanders, I only needed to richen the mixture for both problems. I'm not big on drilling extra holes in my car, so I fabricated a custom bracket that takes the place of one of lower dash washers to mount the potentiometer. I tested it today. It wasn't hot enough to verify that it will cure the heat soak condition, but it sure worked awesome to smooth out the idle hunt during warmup. I'm pretty sure it will work to get me over the heat soak condion and allow me to start the car as I can instantly add 500 ohms of resistance to the CHT circuit and cause the mixtrue to richen. I used a 500 ohm pot for this. I'll try a 1,000 ohm pot if the 500 doesn't cure the heat soak problem. A huge thanks to Pbanders for his research thread listed above. (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() |
| BeatNavy |
Jun 8 2019, 06:36 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Elegant solution, Bob (IMG:style_emoticons/default/beer.gif)
I have never had the issues to that extent, although I must admit I always brace myself for a potentially difficult start / re-warmup period after getting gas, running a quick errand, etc. Sometimes it's no issue at all, and sometimes it is (although it hasn't left me stranded yet). I have the hi-torque starter now, and that seems to have mitigated hot start issue somewhat. It is really the only thing that still bothers me about D-Jet. |
| worn |
Jun 8 2019, 07:36 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I also have a 2056 with d-jet. Keep me posted.
| GregAmy |
Jun 9 2019, 06:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Watching.
I've had similar issues with cold idle, but not so much the heat soak problem. I've got a couple of settings on the D-Jet ECU idle mixture that I know where to set, but of course when it's set properly for cold start then it runs rich when warmed up (and vice versa). I've often thought that if we could determine the proper resistance values to accomdate this then the best solution would be a latching relay. Hit the button and the relay closes for a set amount of time (5-10 minutes?) and then automatically opens the circuit. This relay would control both a resistor for the CHT sensor and an electric solenoid AAR valve (seems so silly to me to have to maintain constant power to the AAR after warm up). So...quite interested in what numbers you come up with. |
| IronHillRestorations |
Jun 9 2019, 12:37 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Nice solution!
It's easy to forget that these cars use an injection system from the 60's that was ahead of it's time. Not perfect, but ahead of it's time (IMG:style_emoticons/default/smile.gif) |
| JeffBowlsby |
Jun 9 2019, 02:44 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Watching. I've had similar issues with cold idle, but not so much the heat soak problem. I've got a couple of settings on the D-Jet ECU idle mixture that I know where to set, but of course when it's set properly for cold start then it runs rich when warmed up (and vice versa). The ECU idle control knob only has effect at idle, because it is switched through the TPS. Off idle it has no effect. |
| GregAmy |
Jun 9 2019, 05:55 PM
| McMark |
Jun 10 2019, 06:53 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Did you try the CHT extension? Moves the CHT away from the head so it cools off faster, leading to richer 'hot starts'.
| TX914 |
Jun 10 2019, 08:04 AM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
Nice! Someone with the requisite skills could probably make and market the complete solution as a kit.
| saigon71 |
Jun 10 2019, 10:54 AM
| jim_hoyland |
Jun 10 2019, 11:25 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I like your bracket solution; how did you make it ?
I need one....... |
| saigon71 |
Jun 11 2019, 05:39 AM
| brant |
Jun 11 2019, 08:56 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The ECU idle control knob only has effect at idle, because it is switched through the TPS. Off idle it has no effect. Exactly. Agreed, the adjustment knob is idle only and not a tuning knob. It seems that using a wide band to tune the MPS would provide a better solution having the correct mixture all of the time and not running the risk of tuning the fuel mixture by seat of the pants or sound. |
| mepstein |
Jun 11 2019, 09:15 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I like your bracket solution; how did you make it ? I need one....... It's a 1/4" washer tack welded to a strip of 18GA sheet metal. The sheet metal was bent in a vice using a socket for the radius to match the washer. Shot it with semi-gloss black paint. Very clean install - (IMG:style_emoticons/default/beerchug.gif) |
| jim_hoyland |
Jun 11 2019, 09:28 AM
I like your bracket solution; how did you make it ? I need one....... It's a 1/4" washer tack welded to a strip of 18GA sheet metal. The sheet metal was bent in a vice using a socket for the radius to match the washer. Shot it with semi-gloss black paint. Got it; thank you. |
| ChrisFoley |
Jun 12 2019, 05:32 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
A better solution would be to turn the center screw in the MPS diaphragm about one full turn counterclockwise while not allowing the outer screw to turn at all.
In addition to stabilizing the idle and reducing the likelihood of hot start problems it will probably make more power too. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:44 PM |
