Turn signal wont turn on-solid wven when car off |
Sm914650 |
Jul 20 2019, 09:29 AM
Member Group: Members Posts: 85 Joined: 15-October 18 From: Sf Bay Area Member No.: 22,573 Region Association: Northern California |
Have some issues with break lights currently, had someone switch some bulbs on my right taillight, moved break and turn signals, and now my front right yellow signal bumper wont turn off even when car off..guessing its just the issue with the rear bulbs, but wanted to just post here to see if there was a direct way to solve this.
dirk2056 |
Jul 20 2019, 10:26 AM
Member Group: Members Posts: 93 Joined: 31-July 17 From: cincinnati/Eastside Member No.: 21,304 Region Association: Middle East |
Check the ground connections
mzalanka |
Jul 20 2019, 10:41 AM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
Either your turn signal is on or you have a short and your car thinks it’s on.
These cars are designed to have the same side turn indicators on, solid, if the stalk is down/up and the ignition is OFF. All Porsches do this. It’s so if you park on a dark road in Bavaria someone won’t slam into your parked car from behind. It’s in the owners manual. |
raynekat |
Jul 20 2019, 01:47 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Agree with the above.
Check to make sure your turn signal lever is in the middle off position. If it is either in the left or right position, you'll have a steady light on that side even when the ignition is off. German thing I think. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:23 AM |
