Heater flapper Valve, Connecting the pull wire.... |
jim_hoyland |
Jul 21 2019, 04:48 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I took the flapper valve out. Fixed it, but I'm having a problem reattaching the pull wire to the barrel bolt; is there a trick to getting The bolt and wire lined up ?
Attached image(s) |
mepstein |
Jul 21 2019, 04:55 PM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Jam it open so you get some slack for the cable. Once you get it attached, make sure the valve closes all the way.
IronHillRestorations |
Jul 21 2019, 05:18 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Make sure you've got the jamb nut backed out enough to get the swaged end in the barrel nut. I've also seen hickeys on the ends that made it hard to get in the barrel nut.
Lo-Fi Version | Time is now: 3rd June 2024 - 08:48 AM |
