Is it Springtime?, Or is that time past? |
Beeliner |
Aug 24 2019, 05:01 PM
Member Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States |
The rear trunk pivot assembly can no longer be welded back on the car after snapping apart many times over the decades.
I just received the nifty replacements from J West, so that project looms... (IMG:style_emoticons/default/piratenanner.gif) But... Should I skip the springs and go to the hydraulic lifts? Just asking for opinions... And guidance. (IMG:style_emoticons/default/welder.gif) |
Superhawk996 |
Aug 24 2019, 05:56 PM
914 Guru Group: Members Posts: 5,899 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Rand |
Aug 24 2019, 06:05 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
For me it was easy, lose the stupid wire bars. Also slot the mounts so you can lift the lid up and off. The big lids... I always use gas struts from a pick and pull place. Fun day at the park and the new lids lift nicely. If you can't figure out the ratios and stuff, you could go to camp914.com and just pay the pony. Craig has good stuff.
rjames |
Aug 24 2019, 06:23 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I installed the Jwest solution years ago and haven’t thought about them since.
IMHO installing struts looks tacky and restricts access to the trunk from the side of the car making it more difficult to get the top in. Struts eventually have to be replaced, where as the JWest hinge will be a permanent fix. Your car though, do what you like. |
ClayPerrine |
Aug 24 2019, 08:06 PM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The problem with the torsion bars is nobody bothers to put anti-seize on the shoulder of the pivot bolt. So they seize up, and the torsion bar makes it worse.
I am putting them back on Igor as soon as possible. The previous owner put a set of gas lifts on Elwood. They are going away and I am putting the bars back on it too. Frody has run the torsion bars for 33 years with no difficulty, just anti-seize on the shoulder bolts. |
sixnotfour |
Aug 25 2019, 04:09 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 9th June 2024 - 06:20 AM |
