Un-identified wires...., Helllpppppp. =-) |
Dr. Roger |
Jul 1 2005, 01:07 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Four red wires. One (green)?
I was thinking of bunching these up and connecting to battery. Is this right?? Attached thumbnail(s) |
william harris |
Jul 1 2005, 01:09 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
The four red wires definitely go to the battery. Can't tell what the other wire is. Will post pictures of what they should look like later when I get home. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
eg914 |
Jul 1 2005, 01:10 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
Mine all have a connector on each wire, and are attached to the bolt on the positive battery post. Seems you could bunch the red up and connect. I don't know about the green wire. Where does it come from?
Dr. Roger |
Jul 1 2005, 01:17 PM
Looking closer, it's a green with a red stripe. Large square connector.
ClayPerrine |
Jul 1 2005, 01:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 4 reds hook to the positive post of the battery. The green one is the connection for the oil temp sender. If you have a oil temp gauge there should be a sender in the bottomof the taco plate on the bottom of the right front corner of the motor. The wire from that should run along the engine support bar to the green connector in your picture.
Dr. Roger |
Jul 1 2005, 01:30 PM
you guys are the bomb diggity, Yo ...... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 07:37 AM |
