FS Gauges VDO Oil Temp, Oil Pressure. Voltage, and more, Porsche - VW Audi - Volvo $10 - $25 each |
bdstone914 |
Nov 14 2019, 09:29 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have too many gauges.
These are 52mm VDO gauges from German and Swedish cars. They are smaller than the 60mm Console gauges. The best ones are the steel case early style. Originally in 924 and 944 early. They are $25. The later plastic case and lens are a cheaper but functional design. Those are $10 to $15 each. Separeted by type and style. I have sockets for most of them. May not have light bulbs but they available. Most will have the U shaped mounting brackets and knurl nuts. Can get more pictures. Senders are available from VW or VDO. I have some temp sensors. Anyone making a test stand and need some gauges? Package deals Attached thumbnail(s) |
mobymutt |
Nov 14 2019, 09:52 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I would like to add a pressure gauge and a temperature gauge (with an actual scale), just as auxiliaries in the car. Will any of these work with the stock senders?
914werke |
Nov 14 2019, 10:27 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Holy Cow!
bdstone914 |
Nov 15 2019, 07:12 AM
@mobymutt date='Nov 14 2019, 09:52 PM' post='2762206']
I would like to add a pressure gauge and a temperature gauge (with an actual scale), just as auxiliaries in the car. Will any of these work with the stock senders? [/quote] They do not work with stock senders. The stock pressure sender is only a low pressure warning. |
914bub |
Nov 15 2019, 08:55 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
PM sent for Volvo gauges.
bdstone914 |
Nov 15 2019, 11:57 AM
bdstone914 |
Nov 15 2019, 11:59 AM
Double post
bdstone914 |
Nov 15 2019, 07:28 PM
@mobymutt
date='Nov 14 2019, 09:52 PM' post='2762206'] I would like to add a pressure gauge and a temperature gauge (with an actual scale), just as auxiliaries in the car. Will any of these work with the stock senders? [/quote] They do not work with stock senders. The stock pressure sender is only a low pressure warning. [/quote] Here is a temp and pressure gauge. Attached thumbnail(s) |
mobymutt |
Nov 17 2019, 05:57 PM
Thanks. And just to clarify, you don't have either temp or pressure senders available that would work? I'd have to source those myself?
[quote name='bdstone914' date='Nov 15 2019, 08:28 PM' post='2762401'] @mobymutt date='Nov 14 2019, 09:52 PM' post='2762206'] I would like to add a pressure gauge and a temperature gauge (with an actual scale), just as auxiliaries in the car. Will any of these work with the stock senders? [/quote] They do not work with stock senders. The stock pressure sender is only a low pressure warning. [/quote] Here is a temp and pressure gauge. [/quote] |
914forme |
Nov 17 2019, 06:39 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Bruce, I will take any of the metal case gauges you have, PM me with the number and the cost. I need them for a project (IMG:style_emoticons/default/shades.gif)
bdstone914 |
Nov 17 2019, 10:00 PM
Bruce, I will take any of the metal case gauges you have, PM me with the number and the cost. I need them for a project (IMG:style_emoticons/default/shades.gif) I want to keep some for my cars. Will get a count. What is your email so I can send a pic of what I have? |
scottthephotog |
Nov 18 2019, 04:19 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
Do you have an oil pressure gauge with a matched sender?
bdstone914 |
Nov 18 2019, 11:23 PM
mobymutt |
Nov 19 2019, 07:33 AM
I am interested, if you can also provide senders for both.
914forme |
Nov 19 2019, 07:59 AM
Bruce, I will take any of the metal case gauges you have, PM me with the number and the cost. I need them for a project (IMG:style_emoticons/default/shades.gif) I want to keep some for my cars. Will get a count. What is your email so I can send a pic of what I have? I'll PM you my addy |
scottthephotog |
Nov 19 2019, 10:01 AM
Do you have an oil pressure gauge with a matched sender? Yes. What engine do you have? The 0-5 bar (0-70 psi) is ok for 4 cyl. The ten bar or 150 psi is better for a six. 4 cyl. So the 5 bar would be great. I know you said $25 for a metal case gauge. How much for the sender? Thanks! |
bdstone914 |
Nov 24 2019, 11:01 AM
@scottthephotog
Yes. What engine do you have? The 0-5 bar (0-70 psi) is ok for 4 cyl. The ten bar or 150 psi is better for a six. [/quote] 4 cyl. So the 5 bar would be great. I know you said $25 for a metal case gauge. How much for the sender? Thanks! [/quote] Sorry for the delay in replying. I will sell a sender for $10. I suggest getting a new one. Most of these seep oil. New are $40-$50 last time I checked with VDO. Bruce |
Lo-Fi Version | Time is now: 10th June 2024 - 12:38 AM |
