School me - delrin window roller install |
bbrock |
Jan 18 2020, 12:42 PM
@Mikey914
Can someone school me on installing the little plastic rollers on late door mechanisms? Old ones are riveted on and I'm guessing I can just pop those off and pop the new ones on but would rather know for sure before I wreck the existing worn, but functional, rollers. https://900designs-container.zoeysite.com/i...-type-regulator |
Mikey914 |
Jan 18 2020, 07:36 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These pop onto the scissor assembly. It's a ba cup scocket.
Mark |
jim_hoyland |
Jan 18 2020, 08:02 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Good question...I bought those for my ‘75 too and haven’t figured out how to instal.
Please post some pics when you do the install..... (IMG:style_emoticons/default/smile.gif) |
bbrock |
Jan 18 2020, 08:19 PM
Good question...I bought those for my ‘75 too and haven’t figured out how to instal. Please post some pics when you do the install..... (IMG:style_emoticons/default/smile.gif) Thanks Mark. Wish I could help Jim. I decided to leave the originals on and save the new ones as spares. What I originally thought was wear on the originals turned out to be little pockets molded into the face that I think might be there for grease reservoirs. Anyway, after cleaning them up, they looked pristine so I decided to let sleeping dogs lie. I did try to pry one off with a panel trim tool but the force it required was more than I was willing to try. I was afraid I would bend something or worse. Looks like the new ones would pop on easier than the old ones pop off, so maybe cut the old ones with a blade first before trying to remove? (IMG:style_emoticons/default/confused24.gif) |
914_7T3 |
Jan 18 2020, 10:33 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
My "go to" was to install with a vice grip. Lined the roller opening up to the the ball on the window regulator, tightened the grip and snapped it closed at minimum pressure.
The only rollers I changed were the ones at the bottom of the regulator that roll through the fixed channel. The riveted ones were left "as is" as they were in reasonably good condition. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:06 AM |
