> Nose cone question, easy to R&R?
Mueller
post Feb 10 2020, 10:47 AM
914 Freak!
On my sids shifter I would like to remove the rear cover to do a slight modification.
1. Is it a straight remove and replace job?
2. Do I have to worry about gasket thickness like other gaskets in the transmission?
3. It is magnesium correct?
post Feb 10 2020, 10:59 AM
914-6 GT in waiting
1. Is it a straight remove and replace job? yes. you do have to keep the gear that sits inside the rear cover in place when you lift off the cover. If it falls on the floor, just make sure to put it back before you close up the case.
2. Do I have to worry about gasket thickness like other gaskets in the transmission? no
3. It is magnesium correct? yes
Mueller
post Feb 10 2020, 11:42 AM
914 Freak!
thanks!
Tdskip
post Feb 10 2020, 01:06 PM
One tip, that I have not tired, is a bit of grease to hold the gears in place when reassembling. It can be a bit fiddly otherwise.
Get other confirmation before doing that in case I am wrong.
As @mepstein said, get ready to catch what will want to fall out.
- Lo-Fi Version Time is now: 12th March 2026 - 03:30 PM
