914/6 Tach not working |
Joe C |
Feb 29 2020, 04:48 PM
Newbie Group: Members Posts: 14 Joined: 3-January 19 From: New York Member No.: 22,773 Region Association: North East States |
Does anyone know when Porsche stopped using the inline resistor for the tach on a six?
I have a very late production original '70 and I cant get the tach to work. I'm pretty sure there isn't a resistor on the relay board. Trying to determine if they went to the internal resistor in late '70 production. |
ClayPerrine |
Feb 29 2020, 06:38 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is no resistor in a70 six, but there is a tach amplifier. It is located on the relay board. The amp was used to raise the CD box output to a level that would trigger the tach They were used in 70,but not in 71. Porsche got new circuit boards for the tachs in 70,and they used them in 911s first.
You can fix it by buying a tach for a 911SC, and transferring it's guts to the 70 914 tach. Then open the tach adapter and installing a jumper wire to bypass it. It will look stock, and the tach will work. I can take pictures when I get home if you need them. |
Joe C |
Feb 29 2020, 07:10 PM
There is no resistor in a70 six, but there is a tach amplifier. It is located on the relay board. The amp was used to raise the CD box output to a level that would trigger the tach They were used in 70,but not in 71. Porsche got new circuit boards for the tachs in 70,and they used them in 911s first. You can fix it by buying a tach for a 911SC, and transferring it's guts to the 70 914 tach. Then open the tach adapter and installing a jumper wire to bypass it. It will look stock, and the tach will work. I can take pictures when I get home if you need them. Pics would great, and thanks for the info! |
Lo-Fi Version | Time is now: 11th June 2024 - 04:58 PM |
