Firewall Shift Cover, !$@$#^(*&(**&%@*&%!#%!*@%*$#!(^#$!(^(!#^$ |
ctc911ctc |
Mar 17 2020, 09:52 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
My fingers are raw and my patience is thin,
but I will be at it later today again, if I can get some purchase or perhaps direction from the great people here within the teener collection Is there a secret to getting the firewall side of this thing on the flange? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Mar 17 2020, 09:55 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Helps if the part is flexible. Is this a new or used part?Sounds like something isn't right.
horizontally-opposed |
Mar 17 2020, 09:57 AM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Haven't had the pleasure of this fix, but the subtitle of your thread reminds me of 3-4 various fixes I've made to my 914, and the way I felt while doing it—mostly in days before this forum when you had to "figure it out" on your own.
914world 'tis a blessing.... |
Mikey914 |
Mar 17 2020, 09:59 AM
Try rolling the lip over itself, pressing against the ring on the firewall and flipping it back.
Olympic 914 |
Mar 17 2020, 10:00 AM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
TheCabinetmaker |
Mar 17 2020, 10:07 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Coat with glycerine. Install firewall side first, then the rod flange
Mikey914 |
Mar 17 2020, 10:18 AM
What I'm wondering is if the part is new, if the rubber is too hard. If that is the case DO NOT use anything to pierce the part as you could create a tear of puncture the part. Factory designed it's parts the way they did for a reason. This is why you can't randomly (or by cost) choose materials to make parts. I'm suspecting this may be an issue here. |
914e |
Mar 17 2020, 10:33 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
914e |
Mar 17 2020, 10:47 AM
My fingers are raw and my patience is thin, but I will be at it later today again, if I can get some purchase or perhaps direction from the great people here within the teener collection Is there a secret to getting the firewall side of this thing on the flange? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) I know the feeling, I spent half of Sunday fighting the front upper targa weatherstrip getting it to go into that aluminum trim channel. I still have the passenger side to go. The frustrating part is knowing when it was built nothing took more than a few minutes. Installing that cover boot is on my list for this weekend. I wonder if I start swearing at now it will pop right on out of fear? |
Al Meredith |
Mar 17 2020, 10:54 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I've heard the "KY" will work best
hndyhrr |
Mar 17 2020, 11:23 AM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
bbrock |
Mar 17 2020, 11:32 AM
Coat with glycerine. Install firewall side first, then the rod flange Where do you find glycerine? I tried all the local drug stores. Drug store probably has it, the trick is finding someone who knows where it is. After about a half hour with a clerk's help who asked about every one of his co-workers, he finally found it WAY down on a bottom shelf in the skin care section. |
cary |
Mar 17 2020, 12:58 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
ctc911ctc |
Mar 17 2020, 01:15 PM
Like the "engine-in" oil cooler seal replacement?
(IMG:style_emoticons/default/blink.gif) Haven't had the pleasure of this fix, but the subtitle of your thread reminds me of 3-4 various fixes I've made to my 914, and the way I felt while doing it—mostly in days before this forum when you had to "figure it out" on your own. 914world 'tis a blessing.... |
ctc911ctc |
Mar 17 2020, 01:19 PM
Mike,
I believe I bought this from you new, however, i could not find it on your web site today.....????? Will be swearing all afternoon - may try a little heat (very little) Glycerine and then perhaps a little of the suggested motion-lotion. Helps if the part is flexible. Is this a new or used part?Sounds like something isn't right. |
roblav1 |
Mar 17 2020, 02:06 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Palmolive works great when attaching rubber things. Even Marge soaks in it!
Alain V. |
Mar 17 2020, 02:13 PM
Member Group: Members Posts: 161 Joined: 15-March 13 From: Kansas Member No.: 15,655 Region Association: None |
wndsrfr |
Mar 17 2020, 03:58 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Ditto, but grind off the pointy pick end. Then round it on/with the sander. Seems like, because I'm right handed I finish between the 3 and 5 o'clock position. My .02c. (IMG:style_emoticons/default/agree.gif) I use a coat hanger wire bent double then made a tight hook to use.... Remember, "assembly of 914 require great peace of mind" .... |
914sgofast2 |
Mar 17 2020, 04:24 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Plain old Vaseline Petroleum Jelly also works well and much easier to find than glycerine. You can also use liquid dishwashing soap.
r_towle |
Mar 17 2020, 06:06 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What year car/tub is it?
Lo-Fi Version | Time is now: 8th June 2024 - 03:52 AM |
