Installing Front Turn Signal Boots, another CV-19 project |
76-914 |
Apr 17 2020, 04:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Like the title says............I'd have avoided this another year if possible. Heck, one was in pretty good shape anyway. (IMG:style_emoticons/default/beer.gif) I can't remember when I bought these from 914rubber but it was awhile back. Besides, some of my most serious screwups were the result of installing some random, inexpensive and simple part. (IMG:style_emoticons/default/mad.gif) I'm happy to say that, as I learned, this isn't terribly involved after all. I don't how long I spent but you should be able to this some Saturday morning, easy.
Jack up the front end and remove both tires. You can do this with the tires in place but I have a short temper and need all the room I can get. (IMG:style_emoticons/default/shades.gif) Disconnect the Neg battery cable. Remove the side reflector and lens assembly from fender. Cut and remove the old side lamp rubber boot and the main boot but leave the part surrounding the harness where it penetrates the fender. This protects the wires and acts as a 3rd hand later. The boot before & after : Mark and remove the wires from the bucket and remove the 10mm nut and attaching clamp. It gives that little bit of extra room that keeps me from going ballistic. (IMG:style_emoticons/default/biggrin.gif) Then cut a piece of heat shrink tube about 2" long and slide one over each bundle of wires. Cut 2 lengths of baling or copper wire appx 12" long. Take a very small tie wrap or safety wire and tie the wires together as shown below. This picture is actually a "fail" but it will give you the idea. Eventually I cut the clear tie wrap and hooked the wire around the red or lower one. Otherwise the wires would bunch up when pulled upon. The same is done to the side marker lead which only has 2 wires. Before you shrink the tube over the spade terminals be sure you line them up in a manner that produces the smallest diameter. Remember, this operation is akin to stretching a Gnat's Ass over a Rain Barrel and just like the Gnat we want to make that Rain Barrel as small as possible. Before installing I placed a liberal amount of glycerine inside the "thru" section of the boot. Next I fed both pull wires through the boot and out their respective openings. Take the wire attached to the side lamp (the lead with only 2 wires) and wrap the other end around something rigid and pull it taunt. You may tie to a drop link, like I did, or even a Zert fitting on the master cylinder. Refer to pic. Look closely and you can see the shrink wrapped wires that aren't inside the boot yet. These will be pulled in after the other section is pulled through. Clean the lube off your hands, grab the boot and pull it up the tie wire while maneuvering the boot as required. It may take a small pick to stretch the lip of the boot over some hump but it will pull through if you lubed the wires and boot well. Once this lead is pulled through & into place remove the shrink wrap, zip tie and pull wire. The 2nd wire which is connected to the 3 wire bundle is now pulled into the boot to the point that you can see the spades. It won't make the turn as configured so you'll need to remove the shrink wrap, zip tie and pull wire while it sits inside the boot. I used an Exacto knife to reach in while being careful not to knick a wire. Once this is cleaned up you can retrieve the wires with some needle nose pliers. Don't install the side lens until you have the boot pulled over the lamp housing as you will need to reach in that hole to grab on of the rubber ears. I didn't Lub thesis I wanted it to stick and boy does it. It takes little effort but wound up with an excellent fit. Great product @Mikey914 . BONUS QUESTION: Who can spot the oddity in the 4th to last pic of the side marker lamp? Attached image(s) |
Spoke |
Apr 17 2020, 05:48 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Nice job. Not one of the fun projects on the 914.
Mikey914 |
Apr 17 2020, 06:43 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
nice technique.
rgalla9146 |
Apr 17 2020, 07:15 PM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Following your instructions makes this very difficult job 'doable' .....you've described it so well.
Thank you |
aharder |
Apr 17 2020, 08:08 PM
Advanced Member Group: Members Posts: 4,405 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
wish I had this before I did mine. I cussed all night doing mine (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/boid.gif) (IMG:style_emoticons/default/blowtorch.gif) (IMG:style_emoticons/default/spank.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
I'm sure this would have saved me a couple of hours !! Nice Job ! |
cary |
Apr 17 2020, 11:38 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Must have been an electrician in his first life.
bbrock |
Apr 18 2020, 07:06 AM
I vote for this moving to classics so it is easy to find. This is one of those jobs I thought would be a quick 5 minute deal, but NO. Kent's tips would make it SO much easier. (IMG:style_emoticons/default/beerchug.gif)
913B |
Apr 20 2020, 10:27 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/pray.gif)
Great Job ! Another To Do project when the time comes. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:56 AM |
