> push nuts for engine grill
dt4
post May 17 2020, 12:37 PM
Region Association: England
I have searched and browsed 914rubber but i am not finding the size or product I need to fix the grill to the engine lid, any pointers please?
Craigers17
post May 17 2020, 01:04 PM
QUOTE(dt4 @ May 17 2020, 12:37 PM) *
I'm in the process of refreshing the Deck lid and grill parts as well. I haven't gotten them fully sanded and painted yet, so I haven't reassembled. However, Mark at 914 Rubber told me that they don't include those push nuts in their Engine Deck Lid Kit because they have to get them from the Porsche dealer and they are pricey(if you call them, they CAN get them for you though). Since I'm not doing a Concours resto, I just went to the hardware store and bought these:
I test fit these on the grill "prongs", and I think they are going to work fine.
Good Luck!
dt4
post May 17 2020, 01:18 PM
thanks, they look just the job, I will measure up the prongs and order similar on line
bbrock
post May 17 2020, 02:00 PM
They are still available through Porsche.
Craigers17
post May 17 2020, 03:26 PM
After doing a little more research going through the Porsche Parts catalog, I'm pretty sure this is the actual speed nut in question:
https://www.aasesales.com/products/h0c-b52-15i-104982
You can search on the part # and try to find different vendors with the best price. Doing a quick search, I found them here at $2.00/EA. For comparison, the push nut pictured in my first post above is around $ .42/EA at ACE Hardware. I think you need 18 of these to do the engine grill and both side grills.
914Sixer
post May 17 2020, 05:39 PM
Yep, that is the original one. Use the part number listed 999 507 220 40 and do on line search. Found them for $1.59 each at Gaudin Porsche.
Ampex351
post May 17 2020, 06:03 PM
QUOTE(dt4 @ May 17 2020, 01:37 PM) *
914 Rubber DOES have them. I just checked a while ago. I think theyre listed under "nuts and bolts". Or you can call them during the week.
mb911
post May 17 2020, 07:27 PM
I bought some from 914rubber.. They are the push on speed nuts with Some sort of buytl under them I believe.
dt4
post May 18 2020, 03:42 AM
Thanks everyone, I will track some down
dr914@autoatlanta.com
post May 18 2020, 09:05 AM
99950722040 have plenty in stock
QUOTE(dt4 @ May 17 2020, 11:37 AM) *
914_7T3
post May 18 2020, 09:15 AM
QUOTE(mb911 @ May 17 2020, 06:27 PM) *
Yes and different from the "Genuine" Porsche ones that are now hard plastic instead of the original ones that were much softer like rubber.
Neither is ideal as the butyl ones get gooey in the heat and the plastic ones are real tough to snap on. (IMG:style_emoticons/default/sad.gif)
mb911
post May 18 2020, 11:31 AM
QUOTE(914_7T3 @ May 18 2020, 07:15 AM) *
Agreed
dt4
post May 19 2020, 06:44 AM
I picked these up for $3 for 25
They do the job perfectly although they are single use but for that price (IMG:style_emoticons/default/beerchug.gif) Attached Image
- Lo-Fi Version Time is now: 14th March 2026 - 01:08 AM
