| Jgilliam914 |
May 23 2020, 07:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,376 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
I have 2 that are painted black and I would like to go back to original.
Will pay according condition |
| bdstone914 |
May 23 2020, 09:52 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,390 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Jgilliam914
' date='May 23 2020, 06:20 PM' post='2818337'] I have 2 that are painted black and I would like to go back to original. Will pay according condition [/quote] What year is the car? The posts are different between the early non reinforced and layer doors. I have a pile of them. Bruce |
| Jgilliam914 |
May 23 2020, 10:34 PM
Bruce I need them for a 72
| bdstone914 |
May 24 2020, 08:31 AM
@Jgilliam914
Bruce I need them for a 72 [/quote] 72 should be early. Can you check the inside of the post and see if you have a thick fuzzy strip (late ) or bare (early) ? Picture is a late type. Attached thumbnail(s) |
| horizontally-opposed |
May 24 2020, 05:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
'72 car should be an early guide, without the felt.
Have a pretty nice used RH (?) guide. Not perfect, but will price fairly and can figure out shipping at commercial rates. |
| Jgilliam914 |
May 25 2020, 08:41 AM
72 should be early. Can you check the inside of the post and see if you have a thick fuzzy strip (late ) or bare (early) ? Picture is a late type. [/quote I just checked them And they are shaved clean with no fuzzes |
| Mikey914 |
May 26 2020, 02:08 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The aluminum is the same for all years. The only difference is the bracket under the triangle window seal. The early has a tab that would jut into the seal. The later no longer had them. They can be removed
Lo-Fi Version | Time is now: 24th September 2026 - 11:09 PM |
